Transaxle question. How many teeth on 4th gear. |
JMT |
Mar 21 2017, 05:13 PM
Newbie Group: Members Posts: 36 Joined: 19-August 16 From: Ca Member No.: 20,316 Region Association: None |
Hello everybody. I'm in the middle of a transaxle rebuild and my 4th gear has a "B" marked on it. I have a gear chart and that's a first gear, this for sure was in the 4th gear spot. Shouldn't it have a "V" instead? Does anyone know how many teeth are on a 4th gear so I can confirm?
Thanks. Jeff |
Mar 21 2017, 05:41 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Should be a "V" gear, 27:25.
At least, according to Charlie Davis' page: http://members.rennlist.com/chuxter/901&915ratios.htm --DD |
JMT |
Mar 21 2017, 07:57 PM
Thanks DD. I'm just thinking if I have a tooth count then I'll know for sure It's a 'V" 4th gear regardless of the marking. I read that 914 gears were not marked over on Pelican.
Thanks Jeff. |
JMT |
Mar 21 2017, 08:59 PM
Ok, It's #25 teeth. Hence the 27:25 ratio for the gear stack. What a moron I am.
Lo-Fi Version | Time is now: 6th May 2024 - 10:14 AM |
