911 oil pressure sending unit |
Harpo |
Mar 22 2017, 10:21 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I sent my gauges and senders out to Palo Alto to have them calibrated. When I removed my oil pressure sending unit I failed to keep track of where the wires go. One is labeled "G" and the other is "WK". One of these goes to the gauge and the other goes to the engine wiring harness.
Thanks for your help David |
Mark Henry |
Mar 22 2017, 10:29 AM
Usually they both go to the gauge, but IIRC
Are you sure it's just one wire to the gauge? Likely one wire was already there through the harness and only one extra wire was needed to be run. edit: brain fart moment and now the pic came up for me, that's a aftermarket VDO combo sender. |
Lo-Fi Version | Time is now: 27th May 2024 - 11:32 AM |
