Whats wrong with my Carbs?, wants to stall leaving the traffic light. |
HansJan |
Mar 25 2017, 09:12 PM
Member Group: Members Posts: 394 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
Not having much luck with the Search function. The car: 1972, with 103mm cylinders (2.3l), aftermarket cam and larger valves with double springs. Fuel supply: Dual EMPI HPMX 44 Carburetors, Jets: .55 Idle, 1.55 main, Air 1.75. History: After car-fire engine was out, heads taken off and some studs and springs replaced. Changed to quieter exhaust. Had trouble with dialing in the carburetors and changed the jets to the recommendations from EMPI (see above). It runs a lot better now. Remaining complaint; The car runs pretty good (especially above 2,800) RPM. However; It takes me a while to leave after each stop (stop signs traffic lights etc) because the car want to stall. When I push the accelerator to quickly the RPM dips down, and car will die. Only when I ease on the paddle very gently, it will increase in RPM, and I can lift clutch at above 1,500 RPM. Anyone here understands this issue? |
forrestkhaag |
Mar 27 2017, 03:10 PM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Also (Kieth) didn't we both notice exceptional improvments in my HPMX40's and your Weber 44's when we tapped and plugged the non-functional choke circuit ports?
Also / agree with the timing function needing to be right on the advance. Mine on the type 4 was 32-34 degrees...... otherwise power was suffering and I would experience lag on start off. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 1st May 2024 - 08:43 AM |
