Whats wrong with my Carbs?, wants to stall leaving the traffic light. |
HansJan |
Mar 25 2017, 09:12 PM
Member Group: Members Posts: 394 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
Not having much luck with the Search function. The car: 1972, with 103mm cylinders (2.3l), aftermarket cam and larger valves with double springs. Fuel supply: Dual EMPI HPMX 44 Carburetors, Jets: .55 Idle, 1.55 main, Air 1.75. History: After car-fire engine was out, heads taken off and some studs and springs replaced. Changed to quieter exhaust. Had trouble with dialing in the carburetors and changed the jets to the recommendations from EMPI (see above). It runs a lot better now. Remaining complaint; The car runs pretty good (especially above 2,800) RPM. However; It takes me a while to leave after each stop (stop signs traffic lights etc) because the car want to stall. When I push the accelerator to quickly the RPM dips down, and car will die. Only when I ease on the paddle very gently, it will increase in RPM, and I can lift clutch at above 1,500 RPM. Anyone here understands this issue? |
r_towle |
Mar 25 2017, 09:45 PM
Custom Member Group: Members Posts: 24,560 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I would certainly check the distributor, advance weights and dwell/timing first .
I personally prefer 40 mm on that motor with the smaller ventures which makes off the line (your issue) more smooth with a faster air flow going into the motor. You can do this two ways, both will cost the same. 1) bring it to a shop with a Dyno to tune the carbs. 2) throw smaller venturis in to increase the velocity of the charge...leave the rest as is. The increased velocity will draw in more fuel. With smaller vents you will top out sooner, but you will increase lower rpm response. |
Lo-Fi Version | Time is now: 24th April 2024 - 07:58 AM |
