Whats wrong with my Carbs?, wants to stall leaving the traffic light. |
HansJan |
Mar 25 2017, 09:12 PM
Member Group: Members Posts: 394 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
Not having much luck with the Search function. The car: 1972, with 103mm cylinders (2.3l), aftermarket cam and larger valves with double springs. Fuel supply: Dual EMPI HPMX 44 Carburetors, Jets: .55 Idle, 1.55 main, Air 1.75. History: After car-fire engine was out, heads taken off and some studs and springs replaced. Changed to quieter exhaust. Had trouble with dialing in the carburetors and changed the jets to the recommendations from EMPI (see above). It runs a lot better now. Remaining complaint; The car runs pretty good (especially above 2,800) RPM. However; It takes me a while to leave after each stop (stop signs traffic lights etc) because the car want to stall. When I push the accelerator to quickly the RPM dips down, and car will die. Only when I ease on the paddle very gently, it will increase in RPM, and I can lift clutch at above 1,500 RPM. Anyone here understands this issue? |
flyer86d |
Apr 12 2017, 12:05 AM
Member Group: Members Posts: 421 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
I agree with the above post. I had this happen on a customers car. Take the carb off, remove the idle jets and adjustment screws and blast all of the passages out with carb clean with the plastic wand on the spray nozzle. It worked for me. There was gunk in the idle passage in the carb.
Lo-Fi Version | Time is now: 26th April 2024 - 05:29 AM |
