Stereo speaker placement idea you might like, 6 speakers, sounds great even with no roof on! |
oakdalecurtis |
Mar 26 2017, 04:42 AM
Oakdalecurtis Group: Members Posts: 1,327 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I have two speakers on each side in front, one in the original footwell location and one in the door, wired together in series as one channel. Each pair make up the front left channel on one side and the front right channel on the other side. Then I have two speakers in the center of the backrest. One is the left rear channel and one is the right rear channel. When I balance the music out from front to back, it's really easy to hear the sound because it's coming from very close to your ears in the backrest. The front two speakers on each side compensate for their inferior position by being paired for each front channel. Don't need an amplifier. Works better than I could have hoped! (Might also notice the velcro strap around the fuse cover to keep it from being bumped off accidently)
GeorgeRud |
Mar 26 2017, 10:16 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
If you like the sound, it's your car - go for it. I always thought some tweeters around the headrests or high up on the windshield pillars would be a good idea as well. I'd be hesitant to cut into original, good door cards or rear upholstery, but since you can get replacements that could be used, the sky's the limit.
oakdalecurtis |
Mar 26 2017, 10:58 AM
If you like the sound, it's your car - go for it. I always thought some tweeters around the headrests or high up on the windshield pillars would be a good idea as well. I'd be hesitant to cut into original, good door cards or rear upholstery, but since you can get replacements that could be used, the sky's the limit. Actually, even though I've had the car for twenty years, it came to me with the door speakers already there. I just added the two back rest speakers to improve the sound quality while driving. I have never hit the flush speaker grills with my elbows, but I also have a raised console in the center to rest my right arm on while driving. Even though I have returned many items on the car toward original items, if doing some modification to the car makes it more fun to drive or use, I alter it in a heartbeat. |
Lo-Fi Version | Time is now: 24th May 2024 - 04:40 PM |
