Stereo speaker placement idea you might like, 6 speakers, sounds great even with no roof on! |
oakdalecurtis |
Mar 26 2017, 04:42 AM
Oakdalecurtis Group: Members Posts: 1,325 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I have two speakers on each side in front, one in the original footwell location and one in the door, wired together in series as one channel. Each pair make up the front left channel on one side and the front right channel on the other side. Then I have two speakers in the center of the backrest. One is the left rear channel and one is the right rear channel. When I balance the music out from front to back, it's really easy to hear the sound because it's coming from very close to your ears in the backrest. The front two speakers on each side compensate for their inferior position by being paired for each front channel. Don't need an amplifier. Works better than I could have hoped! (Might also notice the velcro strap around the fuse cover to keep it from being bumped off accidently)
ConeDodger |
Mar 26 2017, 11:33 PM
Apex killer! Group: Members Posts: 23,589 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I'm no audiophile. In fact, I'm a bit deaf after visiting a sandbox in the middle-east. But, I would never cut my doors. I used an early version of 914Rubber factory speaker housing replacement with Polk component midrange speakers. I also used the passenger footwell sub housing for base. Then to even it all out, I surface mounted the Polk component tweeters. I could have dropped them into holes in the dash but I couldn't bring myself to cut a panel.
The sound is very rich. Again, I'm not an audiophile. But it's pretty damned good... Attached image(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 08:52 AM |
