Intermittent starter issues... |
SKL1 |
Mar 26 2017, 03:41 PM
Senior Member Group: Members Posts: 1,597 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Noticed recently the starter acting up on my '73. I have the stronger starter (can't remember where I got it as it's been a few years, but the same one on my '71 I got from Alan Johnson Racing way back when) and every so often I just get the "click" with no start- sometimes when cold, ocassionally when warm.
In the old days (and I mean really old days, back in the '70's) when that happened you'd hit the solenoid with a hammer and that would take care of it. This starter is probably 5-6 years old, but used pretty sparingly... now I'm a little nervous to take it somewhere if I'm not on a hill! Eventually it will start but seems pretty unpredictable. Any ideas??? |
euro911 |
Apr 21 2017, 12:29 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,847 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
The heavy wire needs to be a large gauge wire to carry the load current. I believe the OEM wire from the battery is at least #2 AWG. (Verify against the OEM wire gauge from the battery).
You can reuse the original (yellow) wire from the ignition switch (which I believe is a #10 AWG), attach it to the small 'S' terminal on the new relay. I modified/annotated a diagram found in the WWW |
Mark Henry |
Apr 21 2017, 05:15 PM
The heavy wire needs to be a large gauge wire to carry the load current. I believe the OEM wire from the battery is at least #2 AWG. (Verify against the OEM wire gauge from the battery). You can reuse the original (yellow) wire from the ignition switch (which I believe is a #10 AWG), attach it to the small 'S' terminal on the new relay. I modified/annotated a diagram found in the WWW Sigh.... I'll never understand why people need to make something simple more complex. (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 08:59 AM |
