Intermittent starter issues... |
SKL1 |
Mar 26 2017, 03:41 PM
Senior Member Group: Members Posts: 1,596 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Noticed recently the starter acting up on my '73. I have the stronger starter (can't remember where I got it as it's been a few years, but the same one on my '71 I got from Alan Johnson Racing way back when) and every so often I just get the "click" with no start- sometimes when cold, ocassionally when warm.
In the old days (and I mean really old days, back in the '70's) when that happened you'd hit the solenoid with a hammer and that would take care of it. This starter is probably 5-6 years old, but used pretty sparingly... now I'm a little nervous to take it somewhere if I'm not on a hill! Eventually it will start but seems pretty unpredictable. Any ideas??? |
porschetub |
Mar 26 2017, 11:43 PM
Advanced Member Group: Members Posts: 4,695 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Starter relay is partly a bandage for a broken leg ,yes it takes load off the electrics but really isn't that hard to pull a starter and clean it ,providing you have a good ignition switch and all connections to starter are 100% to said starter.
I don't expect an aftermarket starter to last as long as a genuine one buts that's my thoughts. Good luck. |
Mark Henry |
Mar 27 2017, 06:47 AM
Starter relay is partly a bandage for a broken leg ,yes it takes load off the electrics but really isn't that hard to pull a starter and clean it ,providing you have a good ignition switch and all connections to starter are 100% to said starter. I don't expect an aftermarket starter to last as long as a genuine one buts that's my thoughts. Good luck. I heard this argument many times before, to me it's a very thin slice of truth in the middle of a (IMG:style_emoticons/default/bs.gif) sandwich. And these days I'd do it just to take the load off the ignition switch, the new repop switches are total garbage. YMMV |
Lo-Fi Version | Time is now: 29th March 2024 - 06:30 AM |
