Intermittent starter issues... |
SKL1 |
Mar 26 2017, 03:41 PM
Senior Member Group: Members Posts: 1,597 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Noticed recently the starter acting up on my '73. I have the stronger starter (can't remember where I got it as it's been a few years, but the same one on my '71 I got from Alan Johnson Racing way back when) and every so often I just get the "click" with no start- sometimes when cold, ocassionally when warm.
In the old days (and I mean really old days, back in the '70's) when that happened you'd hit the solenoid with a hammer and that would take care of it. This starter is probably 5-6 years old, but used pretty sparingly... now I'm a little nervous to take it somewhere if I'm not on a hill! Eventually it will start but seems pretty unpredictable. Any ideas??? |
GregAmy |
Mar 27 2017, 03:37 PM
Advanced Member Group: Members Posts: 2,264 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I think we need to stop calling this a "hot start relay kit". It's not a "hot start" problem, it's a "shitty electrical design" problem that just so happens to rear its ugly head more often when the car is hot because the starter solenoid is pulling more amps.
I don't know if this is the original poster's problem. No one can say that unless more hands-on troubleshooting is done. But we should all be installing this upgrade, simply because it's a better design. So I hereby declare this product to now be called "the shitty electrical design" kit, which can be solved for $26 shipped from Amazon (The Bird has it for <$30, free shipping if in a $79 or more order). https://www.amazon.com/dp/B001COAX78/ Edit: Additional top tip. Install the fuseholder where you can reach it without soiling a nice pair of work khakis and golf shirt. Yes, I've popped the 15A fuse on mine, a couple of times (tells you how much current that thing draws). And yup, I learned after the first one and re-positioned it into the engine compartment. |
HalfMoon |
Apr 11 2017, 08:21 AM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
I think we need to stop calling this a "hot start relay kit". It's not a "hot start" problem, it's a "shitty electrical design" problem that just so happens to rear its ugly head more often when the car is hot because the starter solenoid is pulling more amps. I don't know if this is the original poster's problem. No one can say that unless more hands-on troubleshooting is done. But we should all be installing this upgrade, simply because it's a better design. So I hereby declare this product to now be called "the shitty electrical design" kit, which can be solved for $26 shipped from Amazon (The Bird has it for <$30, free shipping if in a $79 or more order). https://www.amazon.com/dp/B001COAX78/ Edit: Additional top tip. Install the fuseholder where you can reach it without soiling a nice pair of work khakis and golf shirt. Yes, I've popped the 15A fuse on mine, a couple of times (tells you how much current that thing draws). And yup, I learned after the first one and re-positioned it into the engine compartment. I ordered that relay kit from Amazon. It was TOTALLY bogus and wasted my time. They do not send the 'kit", just the relay. $25 for a $5 relay? Rippoff city. |
Mark Henry |
Apr 11 2017, 08:35 AM
I think we need to stop calling this a "hot start relay kit". It's not a "hot start" problem, it's a "shitty electrical design" problem that just so happens to rear its ugly head more often when the car is hot because the starter solenoid is pulling more amps. I don't know if this is the original poster's problem. No one can say that unless more hands-on troubleshooting is done. But we should all be installing this upgrade, simply because it's a better design. So I hereby declare this product to now be called "the shitty electrical design" kit, which can be solved for $26 shipped from Amazon (The Bird has it for <$30, free shipping if in a $79 or more order). https://www.amazon.com/dp/B001COAX78/ Edit: Additional top tip. Install the fuseholder where you can reach it without soiling a nice pair of work khakis and golf shirt. Yes, I've popped the 15A fuse on mine, a couple of times (tells you how much current that thing draws). And yup, I learned after the first one and re-positioned it into the engine compartment. I ordered that relay kit from Amazon. It was TOTALLY bogus and wasted my time. They do not send the 'kit", just the relay. $25 for a $5 relay? Rippoff city. To me the Bosch relay is a POS for this application, likely the #1 reason some say the relay doesn't work well. It's a horn relay and it's not waterproof. Get the Ford solenoid, suck it up, quit fuching whining about it being a Ford part and do it right the first time. (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 19th April 2024 - 06:07 PM |
