Intermittent starter issues... |
SKL1 |
Mar 26 2017, 03:41 PM
Senior Member Group: Members Posts: 1,597 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Noticed recently the starter acting up on my '73. I have the stronger starter (can't remember where I got it as it's been a few years, but the same one on my '71 I got from Alan Johnson Racing way back when) and every so often I just get the "click" with no start- sometimes when cold, ocassionally when warm.
In the old days (and I mean really old days, back in the '70's) when that happened you'd hit the solenoid with a hammer and that would take care of it. This starter is probably 5-6 years old, but used pretty sparingly... now I'm a little nervous to take it somewhere if I'm not on a hill! Eventually it will start but seems pretty unpredictable. Any ideas??? |
76-914 |
Apr 13 2017, 08:11 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,490 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
FWIW and IIRC, the Ford solenoid requires ~3.9v to actuate where as the Bosch requires ~9v. (IMG:style_emoticons/default/beerchug.gif)
Mark Henry |
Apr 13 2017, 08:33 AM
FWIW and IIRC, the Ford solenoid requires ~3.9v to actuate where as the Bosch requires ~9v. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) About right, but the Standard SS-571 Starter Solenoid mentioned earlier in this thread is a 6V solenoid and it takes even less volts to kick it in. Amps for sure less than 8amp, I've never heard of anyone blowing a fuse, I've never seen it happen. I've never used or seen the need for an in-line fuse for the Ford solenoid. This 6V solenoid works fine with 12V and is my preferred solenoid. Ask for a pre-1967 ford fender mount starter solenoid at your FLAPS. Even Slits approved of this solenoid. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 24th April 2024 - 08:01 PM |
