Intermittent starter issues... |
SKL1 |
Mar 26 2017, 03:41 PM
Senior Member Group: Members Posts: 1,597 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Noticed recently the starter acting up on my '73. I have the stronger starter (can't remember where I got it as it's been a few years, but the same one on my '71 I got from Alan Johnson Racing way back when) and every so often I just get the "click" with no start- sometimes when cold, ocassionally when warm.
In the old days (and I mean really old days, back in the '70's) when that happened you'd hit the solenoid with a hammer and that would take care of it. This starter is probably 5-6 years old, but used pretty sparingly... now I'm a little nervous to take it somewhere if I'm not on a hill! Eventually it will start but seems pretty unpredictable. Any ideas??? |
porschetub |
Mar 26 2017, 11:43 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Starter relay is partly a bandage for a broken leg ,yes it takes load off the electrics but really isn't that hard to pull a starter and clean it ,providing you have a good ignition switch and all connections to starter are 100% to said starter.
I don't expect an aftermarket starter to last as long as a genuine one buts that's my thoughts. Good luck. |
worn |
Apr 11 2017, 12:45 PM
can't remember Group: Members Posts: 3,147 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Starter relay is partly a bandage for a broken leg ,yes it takes load off the electrics but really isn't that hard to pull a starter and clean it ,providing you have a good ignition switch and all connections to starter are 100% to said starter. I don't expect an aftermarket starter to last as long as a genuine one buts that's my thoughts. Good luck. That may be... But after replacing the starter more than once I learned that the wire gauge to and from the ignition switch is a bit thin for the work of the solenoid. Yeah it is a relay to pull a relay but the solenoid draws a lot of juice. |
Jeffs9146 |
Apr 13 2017, 11:04 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Starter relay is partly a bandage for a broken leg ,yes it takes load off the electrics but really isn't that hard to pull a starter and clean it ,providing you have a good ignition switch and all connections to starter are 100% to said starter. I don't expect an aftermarket starter to last as long as a genuine one buts that's my thoughts. Good luck. That may be... But after replacing the starter more than once I learned that the wire gauge to and from the ignition switch is a bit thin for the work of the solenoid. Yeah it is a relay to pull a relay but the solenoid draws a lot of juice. The ford relay is a bypass to the starter relay, not a solenoid to pull a solenoid like the Bosch is. It sends direct 12v to the main starter power circuit and requires less ign power to trigger. |
GregAmy |
Apr 13 2017, 11:27 AM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
The ford relay is a bypass to the starter relay, not a solenoid to pull a solenoid like the Bosch is. It sends direct 12v to the main starter power circuit and requires less ign power to trigger. It's overkill for the job, for sure. In the end, the whole point of the activity is to discontinue powering the starter solenoid through the ignition switch. Whatever it takes... :shrug: |
Lo-Fi Version | Time is now: 26th April 2024 - 08:55 AM |
