Intermittent starter issues... |
SKL1 |
Mar 26 2017, 03:41 PM
Senior Member Group: Members Posts: 1,597 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Noticed recently the starter acting up on my '73. I have the stronger starter (can't remember where I got it as it's been a few years, but the same one on my '71 I got from Alan Johnson Racing way back when) and every so often I just get the "click" with no start- sometimes when cold, ocassionally when warm.
In the old days (and I mean really old days, back in the '70's) when that happened you'd hit the solenoid with a hammer and that would take care of it. This starter is probably 5-6 years old, but used pretty sparingly... now I'm a little nervous to take it somewhere if I'm not on a hill! Eventually it will start but seems pretty unpredictable. Any ideas??? |
Mark Henry |
Apr 16 2017, 09:27 AM
Do it my way, carefully bend the mount bracket, careful not to stress the bracket to the plastic solenoid housing and enlarge the hole and it will bolt right to the bottom starter stud/nut. Buy or make a male with ring hole quick connect. The only thing my drawing doesn't show is the stock heavy wire battery to starter that's already there .
The bracket must be grounded for the solenoid to work. Not a single hole is drilled or wire cut. I don't agree with the top drawing because it's running the heavy wire to the solenoid then to the starter. A lot of heat is generated at that connection and that could become a failure point. It will work and the Ford solenoid should be fine, but why tempt fate when you don't have to. Takes a poopload of amps to turn over a starter. |
Lo-Fi Version | Time is now: 26th April 2024 - 07:33 PM |
