> Intermittent starter issues...
SKL1
post Mar 26 2017, 03:41 PM
Noticed recently the starter acting up on my '73. I have the stronger starter (can't remember where I got it as it's been a few years, but the same one on my '71 I got from Alan Johnson Racing way back when) and every so often I just get the "click" with no start- sometimes when cold, ocassionally when warm.
In the old days (and I mean really old days, back in the '70's) when that happened you'd hit the solenoid with a hammer and that would take care of it.
This starter is probably 5-6 years old, but used pretty sparingly... now I'm a little nervous to take it somewhere if I'm not on a hill!
Eventually it will start but seems pretty unpredictable. Any ideas???
Spoke
post Apr 23 2017, 07:46 PM
Jerry
Here's the entire starter circuit schematic with the Ford relay. There should only be 5 wires.
Wire Connections:
Existing 914 Wires:
o The heavy red cable from the battery goes directly to the large lug on the starter.
o The smaller red cable from the alternator goes directly to the large lug on the starter.
o The yellow wire from the ignition switch goes to the "S" terminal of the Ford relay
New Wires:
o Red (or any color) wire 12-16GA goes from large lug on the starter to one of the big lugs on the Ford relay; either lug will work.
o Black (or any color wire 12-16GA goes from one of the big lugs on the Ford relay to the Bendix Coil on the starter. either big lug on the Ford relay will work.
SKL1   Intermittent starter issues...   Mar 26 2017, 03:41 PM
Rand   Clean the battery and ground strap connections. It...   Mar 26 2017, 03:45 PM
Tom_T   :agree: And also check the transaxle to undersid...   Mar 26 2017, 07:51 PM
Mark Henry   http://www.914world.com/bbs2/index.php?sho...25905...   Mar 26 2017, 10:36 PM
porschetub   Starter relay is partly a bandage for a broken leg...   Mar 26 2017, 11:43 PM
Mark Henry   Starter relay is partly a bandage for a broken le...   Mar 27 2017, 06:47 AM
worn   Starter relay is partly a bandage for a broken le...   Apr 11 2017, 12:45 PM
Jeffs9146   Starter relay is partly a bandage for a broken l...   Apr 13 2017, 11:04 AM
GregAmy   The ford relay is a bypass to the starter relay,...   Apr 13 2017, 11:27 AM
porschetub   Double post....   Mar 27 2017, 12:21 AM
GregAmy   Agree with Mark. There's just no valid reason...   Mar 27 2017, 06:53 AM
76-914   Got to :agree: w/ Mark & Greg. :beer2:   Mar 27 2017, 02:55 PM
GregAmy   I think we need to stop calling this a "hot s...   Mar 27 2017, 03:37 PM
HalfMoon   I think we need to stop calling this a "hot ...   Apr 11 2017, 08:21 AM
Mark Henry   [quote name='GregAmy' post='2468900' date='Mar 27...   Apr 11 2017, 08:35 AM
HalfMoon   [quote name='HalfMoon' post='2474417' date='Apr 1...   Apr 11 2017, 12:12 PM
SKL1   All my wiring to starter is clean or essentially n...   Mar 27 2017, 10:22 PM
GregAmy   LAME! Definitely complain to Amazon, as WR1 is...   Apr 11 2017, 08:31 AM
GregAmy   The Ford relay is prob a better solution but the B...   Apr 13 2017, 07:09 AM
76-914   FWIW and IIRC, the Ford solenoid requires ~3.9v to...   Apr 13 2017, 08:11 AM
Mark Henry   FWIW and IIRC, the Ford solenoid requires ~3.9v t...   Apr 13 2017, 08:33 AM
SKL1   I ordered the "kit" from Pelican and all...   Apr 13 2017, 11:21 AM
SKL1   Well, ordered the "kit" from both Amazon...   Apr 15 2017, 06:42 PM
Jeffs9146   Well, ordered the "kit" from both Amazo...   Apr 15 2017, 08:15 PM
Mark Henry   Ummm....you do realize that the battery post and t...   Apr 15 2017, 09:52 PM
HalfMoon   Ummm....you do realize that the battery post and ...   Apr 16 2017, 08:06 AM
euro911   :agree: with the Ford type relay. I recently con...   Apr 15 2017, 11:37 PM
Mark Henry   Do it my way, carefully bend the mount bracket, ca...   Apr 16 2017, 09:27 AM
KELTY360   Do it my way, carefully bend the mount bracket, c...   Apr 16 2017, 01:13 PM
HalfMoon   Do it my way, carefully bend the mount bracket, c...   Apr 16 2017, 08:30 PM
euro911   RE: Intermittent starter issues...   Apr 16 2017, 01:43 PM
Jeffs9146   I agree with this method but there is no need ...   Apr 16 2017, 11:26 PM
Mark Henry   Sorry I don't agree. That is how it's...   Apr 17 2017, 07:06 AM
SKL1   Well, my Ford solenoid is coming from Amazon so I...   Apr 16 2017, 10:27 PM
SKL1   OK, I know we're beating a dead horse here, bu...   Apr 20 2017, 10:36 PM
euro911   The heavy wire needs to be a large gauge wire to c...   Apr 21 2017, 12:29 AM
Mark Henry   The heavy wire needs to be a large gauge wire to ...   Apr 21 2017, 05:15 PM
euro911   I think this diagram doesn't leave any unanswe...   Apr 21 2017, 06:05 PM
Hans Jan   The ignition switch on my car is dying as well. I...   Apr 21 2017, 07:01 PM
euro911   They're all the same   Apr 21 2017, 08:14 PM
SKL1   OK, I'm wiring this thing up and don't wan...   Apr 22 2017, 06:12 PM
Spoke   OK, I'm wiring this thing up and don't wa...   Apr 22 2017, 10:22 PM
SKL1   Spoke- all the different schematics do get confus...   Apr 22 2017, 11:25 PM
euro911   The yellow wire comes from the ignition switch and...   Apr 23 2017, 02:06 AM
Mark Henry   Ok...I have a solenoid in my bus and my /6 and tra...   Apr 23 2017, 06:25 AM
Spoke   Here's the entire starter circuit schematic wi...   Apr 23 2017, 07:46 PM
Mark Henry   Enough of the armchair experts....my way of instal...   Apr 24 2017, 06:56 AM
euro911   The starting issue stems from the ignition switch ...   Apr 24 2017, 07:24 PM
- Lo-Fi Version Time is now: 16th April 2024 - 04:52 PM
