| Calwaterbear |
Mar 26 2017, 06:06 PM
Member ![]() ![]() Group: Members Posts: 207 Joined: 15-November 14 From: United States Member No.: 18,123 Region Association: Central California |
Ok guys,
I am taking everyones advise here, picking a particular piece for the project of getting the 72 back on the road. I chose to tackle the interior first - stripped it bare - except for the handbrake, how the heck do you get that thing off? and scraped and grinded and wire wheeled off all the interior rust. Just finishing that part, have to pull the gas and clutch/brake pedals, then ospho up and prime the metal, paint it, then go with new carpet kit, new seat bottoms, and hopefully 914 rubbers new back stop firewall piece. Obviously The heater / defroster tubes are rotten (I assume that those 2" vent tubes coming off both sides , and going into the dash. so I would rather finish up project 1 - the interior rust removal and repaint, before i tackle another piece of the puzzle, but am I getting myself into a bind by not doing the dash at the same time? any advise is appreciated thanks carl j auberry Ca |
| Mikey914 |
Mar 26 2017, 06:57 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,781 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Good plan to finish one before starting another. Do put on your short list to check all the longs and evaluate rust. It can be extensive and is the backbone of the car. If you can assure a good foundation for your project you can assure many years of use without issue and it is more desirable (should you ever have to sell).
| iankarr |
Mar 26 2017, 07:02 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,600 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
But there are a few projects that are related...or at least best tackled "while you're at it." One example is replacing the nylon fuel lines with stainless. Best to do that before the interior is back together since you'll have better access to the tunnel. Post a list of the projects you've got in mind and the brain trust here will be happy to organize them for ya! |
| Front yard mechanic |
Mar 26 2017, 08:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,444 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
Why do today what you can put off till tomorrow (IMG:style_emoticons/default/sunglasses.gif)
| Calwaterbear |
Mar 27 2017, 11:02 AM
(IMG:style_emoticons/default/agree.gif) But there are a few projects that are related...or at least best tackled "while you're at it." One example is replacing the nylon fuel lines with stainless. Best to do that before the interior is back together since you'll have better access to the tunnel. Post a list of the projects you've got in mind and the brain trust here will be happy to organize them for ya! OK so first, I am doing the interior, removing any surface rust, repairing any holes, Ospho the thing, then prime and paint. After that, new or refurbished pedals, a new carpet kit, and refurbishing seats and firewall board. Dash will need a new Dash pad, at least, but right now, I'm not so sure it needs to come out. i'm hoping not to have to do any rewiring once i am done there, I will turn my attention to getting the thing running, original engine, with the original injection. Then once it is running and stopping - then I will go after the exterior, new paint whatever body work is necessary |
| Calwaterbear |
Mar 27 2017, 11:07 AM
Good plan to finish one before starting another. Do put on your short list to check all the longs and evaluate rust. It can be extensive and is the backbone of the car. If you can assure a good foundation for your project you can assure many years of use without issue and it is more desirable (should you ever have to sell). so tell a neophyte what a long is please? |
| Rob-O |
Mar 27 2017, 11:30 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,316 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region
A long is a 'longitudinal'. The longs are behind the outer rocker panel. There is an inner and outer long. Welded together, they compose a very important structure to the unibody of the vehicle. They tend to suffer from rust issues, and specially on the passenger side of the vehicle towards the rear of the car, under and around the rear suspension console and sail panel area.
| Rob-O |
Mar 27 2017, 11:35 AM
By the way, I would suggest what others have here. Check those areas carefully. If the car is severely rusted, spending money on the interior is like putting lipstick on a pig.
I'd also suggest doing all of the mechanical work first. A nice interior is something to be proud of, but you can enjoy the car on the road with a ratty interior. Large portions of that interior will be coming out while performing all kinds of mechanical work, I'd personally wait until the car is all sorted out before tackling the i passenger compartment. |
| Mikey914 |
Mar 28 2017, 09:55 PM
Post lots of pics here most can tell you where to look form your pics. Once your foundation is good you will be able to enjoy the car for many years.
Lo-Fi Version | Time is now: 1st May 2026 - 03:17 AM |
