> Early Hershey emergency thread
914itis
post Mar 26 2017, 06:14 PM
The car was in the garage for the winter , one cold day I started it and put it outside for about a day .
Tried to start to put it back in, it starts and cuts off .Would not idle . I left it alone as it was cold .
I have it a try again yesterday as the weather was decent, same thing . I check for fuel , there is plenty . I think there is spark or it wouldn't start at all.
It's the 6 motor with Webber carbs .
Any ideas?
Thanks .
rgalla9146
post Mar 26 2017, 06:42 PM
QUOTE(914itis @ Mar 26 2017, 08:14 PM) *
Any ideas?
Thanks .
Hey Paul
Plugs are probably wet.
Remove, burn off residue with torch.
Install after cool.
914itis
post Mar 26 2017, 06:50 PM
Thanks .
timothy_nd28
post Mar 26 2017, 06:53 PM
What type of ignition does this 6 motor have?
914itis
post Mar 26 2017, 07:11 PM
Stock ingnitiin with a CDI unit
terryth
post Mar 27 2017, 06:13 AM
Plugged pilot jets in the carbs. I run into this regularly with 11 motorcycles in the garage and modern gas and on my project 914 that has been mostly sitting the last couple of years..
914itis
post Mar 27 2017, 06:34 AM
Jets are clean . First thing I did .
struckn
post Mar 27 2017, 09:07 AM
Bad Gas maybe if untreated.....ethanol lets water settle to the bottom of the tank.
Dominic
post Mar 27 2017, 09:14 AM
Dominic
QUOTE(914itis @ Mar 26 2017, 05:14 PM) *
Any ideas?
Thanks .
Have you replaced the fuel filter? Any rust in the filter?
dcheek
post Mar 27 2017, 09:25 AM
Try spraying starting fluid in carbs with . If it kicks over you have eliminated the ignition system and it must have something to do with the carbs.
Dave
914itis
post Apr 13 2017, 07:59 AM
I did some more digging , it looks like on the drivers's side carb only the barrel to the back of the car squirts , on the passenger front and back squirts but not the middle.
All idle jets are cleaned I pulled them out and insert a needle to clean them.
914itis
post Apr 13 2017, 08:42 PM
I removed the 15 mn bolts and noticed sludge under them.
I then decided to remove one carb. I took it apart , there is so much sludge under the floats and the little snorkel that squirts the gas is clogged. I will be cleaning them tomorrow and reinstall , then move on to the other side.
saigon71
post Apr 14 2017, 07:26 AM
That's crazy sludge Paul!
Good luck with the cleaning...hope all goes well and you can make it to Hershey.
Did that just happen over the winter?
914itis
post Apr 14 2017, 06:23 PM
QUOTE(saigon71 @ Apr 14 2017, 09:26 AM) *
Saigon.
yes it happened over the winter. I started it one day it was fine and two days later, it wouldn't start.
914itis
post Apr 14 2017, 06:27 PM
Today was a good day. (IMG:style_emoticons/default/piratenanner.gif)
I took apart both carbs, the passenger's side wasn't as bad. I disassembled and cleaned all parts. used small wire to clean all gas passages. There was a lot more under the floats; took me 2 Hours and 2 bottles of carb cleaner.
After putting them back together, if fires right up. I am on the road again.
I am guessing bad / sitting gas.
always big thanks to Rory for his guidance.
- Lo-Fi Version Time is now: 16th April 2024 - 03:16 AM
