Trying to drop the front suspension..., but can't get the steering shaft to separate from the U-joint |
bigkensteele |
Mar 26 2017, 07:18 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Can anyone share the secret curse word that will make the U-joint release the steering shaft? (IMG:style_emoticons/default/hissyfit.gif)
I have removed the nut and bolt and driven a screwdriver into the gap to try to get it to let go, but so far, no luck. Is there something I am missing? |
GeorgeRud |
Mar 26 2017, 07:49 PM
If desired, you can leave the rack and pinion in place and simply remove the a-arms and crossmember if you're just replacing the bushings.
Lo-Fi Version | Time is now: 12th May 2024 - 09:10 PM |
