Trying to drop the front suspension..., but can't get the steering shaft to separate from the U-joint |
bigkensteele |
Mar 26 2017, 07:18 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Can anyone share the secret curse word that will make the U-joint release the steering shaft? (IMG:style_emoticons/default/hissyfit.gif)
I have removed the nut and bolt and driven a screwdriver into the gap to try to get it to let go, but so far, no luck. Is there something I am missing? |
cary |
Mar 27 2017, 08:05 PM
Ken did you get the joint soaked down with penetrating oil?
Its more the rust/corrosion on the splines rather than the spread on the split. One of my Tool Whore secret tools is a piece of rebar with a polished end. That's what I use. You just have to get the bond broken. |
bigkensteele |
Mar 28 2017, 09:23 PM
Ken did you get the joint soaked down with penetrating oil? Its more the rust/corrosion on the splines rather than the spread on the split. One of my Tool Whore secret tools is a piece of rebar with a polished end. That's what I use. You just have to get the bond broken. Hi Cary, I really haven't had any time to revisit this since last weekend. My car is not very rusty, and I don't see any rust in the shaft/u-joint, but I will go ahead and shoot some PB Blaster in there tonight and see what happens. Thanks! |
Lo-Fi Version | Time is now: 12th May 2024 - 08:15 AM |
