Alternator belt flipping over |
AndrewBlyholder |
Mar 27 2017, 10:29 AM
Member Group: Members Posts: 109 Joined: 20-September 04 From: Richmond, CA Member No.: 2,791 |
I had my alternator belt flip over at an autocross last weekend. Anyone else ever seen this?
Belt was on the fan and alternator pulleys, just as it should be, but the teeth were facing outward. It had flipped itself inside out! Tension was good. Adjuster bolt still tight. Discovered this after the motor had started cutting out and finally stopped on course. The cause for that was the electrical connections coming off of the starter motor. Those connections include the power supply to the CDI box. So the engine quit due to no spark. The nut had backed off and fell off. (User error on that. Could'a swore I'd torqued that nut...) My theory is that, as the electrical connection was shaking loose, the engine was cutting in and out, and the torque variations from that process caused the fan belt to jump around enough to flip over. But that's just my theory. Anyone else had any experience with a problem like this? Thanks, Andrew Blyholder |
ConeDodger |
Apr 1 2017, 08:35 AM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Alignment caused this for me. i had powder coated something and increased the size by a fraction.
I suspect yours is just belt stretchable and high RPM operation though... |
Lo-Fi Version | Time is now: 17th May 2024 - 04:54 PM |
