'73 2.0, a yellow storage unit find |
arne |
Mar 27 2017, 11:01 AM
Serial Rescuer of old vehicles... Group: Members Posts: 737 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
Well, as I posted at the end of my intro thread ( http://www.914world.com/bbs2/index.php?sho...=303932&hl= ), I bought my 914 over the weekend. We've all heard of barn and garage finds, this car was found in a large storage unit.
Details - '73 2.0, 4732924138, yellow. Rust seems limited to the battery tray, passenger floor and right sail panel (where water obviously got trapped behind the vinyl). The hell hole looks solid at this point. None of the rust appears to be holes yet. Definitely some work to do there. The car was said to run when it was parked in the unit, other people not involved in the sale confirmed that it drove in under its own power. Been sitting for 6 years or so. After it got in, the seller began very rudimentary prep for restoring it, but life got in the way. So about all that was done was to pull all the lenses off. I'm waiting for a flatbed to gather it up now, should have it in my garage later today. Here are a couple of pictures to show the beginning. |
arne |
May 18 2017, 10:41 AM
Pretty sure I don't need to remind anyone here about how one thing leads to another...
Picked up some parts locally to address some of the oil leaks - push rod tubes, oil cooler seals, etc. I also got a rear shift rod bushing as the existing one seemed pretty sloppy. Got the car in the air yesterday, figured I'd start with the shift rod bushing, as that was a separate job from the rest. And that's where the plan started to break down. Pulled the shift linkage bowl/cover down, and found it full of gear oil. Not too surprised, really. But if I'm going to address that, I figured I better just start to really look things over - what else should I be looking at? It would appear that sitting unused for several years magically transforms seals and o-rings into cheese. In addition to the shift linkage, both output flange seals are leaking, the left side especially. So I've started acquiring all the rest of the seals I can think to deal with, as well as the copper exhaust seals as I figure getting to all this stuff will be easier with the heat exchangers out of the way. Progress will resume some time next week after it all arrives. Question - the new rear shift rod bushing doesn't appear to be any better than the one I pulled out. It is not snug on the shift rod, seems to allow close to 1/8" movement. Is that correct? Or is my shift rod a smaller diameter for some reason? |
Lo-Fi Version | Time is now: 15th May 2024 - 02:16 AM |
