'73 2.0, a yellow storage unit find |
arne |
Mar 27 2017, 11:01 AM
Serial Rescuer of old vehicles... Group: Members Posts: 734 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
Well, as I posted at the end of my intro thread ( http://www.914world.com/bbs2/index.php?sho...=303932&hl= ), I bought my 914 over the weekend. We've all heard of barn and garage finds, this car was found in a large storage unit.
Details - '73 2.0, 4732924138, yellow. Rust seems limited to the battery tray, passenger floor and right sail panel (where water obviously got trapped behind the vinyl). The hell hole looks solid at this point. None of the rust appears to be holes yet. Definitely some work to do there. The car was said to run when it was parked in the unit, other people not involved in the sale confirmed that it drove in under its own power. Been sitting for 6 years or so. After it got in, the seller began very rudimentary prep for restoring it, but life got in the way. So about all that was done was to pull all the lenses off. I'm waiting for a flatbed to gather it up now, should have it in my garage later today. Here are a couple of pictures to show the beginning. |
arne |
May 7 2017, 06:57 PM
Updates:
Brakes - Still not 100% happy with the brakes. As appears to be common, I think there is still some air in there somewhere. Going to need to take another stab at bleeding, perhaps at the pressure regulator. Suspension - Have determined that the front was lowered down to where it truly was riding on the bumpstops. After raising it back up to factory height the ride is much improved. Will order new springs for the rear shortly. Oil leaks - Have determined the left side of the motor is dry, all motor leaks are on the right side. Looks like the bulk is from the valve cover, but the oil cooler just above it also looks a bit wet. Cleaning and driving it to see if I can track down the source(s). New items - shift bushings are pretty sad, will address that soon. Also got the oil temp gauge reconnected, but it seems to work spastically. Once after a rather short test drive, I noticed that it had settled and appeared to be working normally, but was indicating rather hot. Will need to decide if the gauge is accurate, and if so if the engine is running hot. Going to need to check the flappers for function. |
Lo-Fi Version | Time is now: 28th April 2024 - 12:57 PM |
