'73 2.0, a yellow storage unit find |
arne |
Mar 27 2017, 11:01 AM
Serial Rescuer of old vehicles... Group: Members Posts: 734 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
Well, as I posted at the end of my intro thread ( http://www.914world.com/bbs2/index.php?sho...=303932&hl= ), I bought my 914 over the weekend. We've all heard of barn and garage finds, this car was found in a large storage unit.
Details - '73 2.0, 4732924138, yellow. Rust seems limited to the battery tray, passenger floor and right sail panel (where water obviously got trapped behind the vinyl). The hell hole looks solid at this point. None of the rust appears to be holes yet. Definitely some work to do there. The car was said to run when it was parked in the unit, other people not involved in the sale confirmed that it drove in under its own power. Been sitting for 6 years or so. After it got in, the seller began very rudimentary prep for restoring it, but life got in the way. So about all that was done was to pull all the lenses off. I'm waiting for a flatbed to gather it up now, should have it in my garage later today. Here are a couple of pictures to show the beginning. |
arne |
May 13 2017, 11:01 AM
Am I correct in thinking the oil pressure sender is on the top side of the motor? If so, it is not leaking, the top side is completely dry. That leaves the right side valve cover as a known leak, and the right push rod tubes and the oil cooler as still suspect.
Stupid Type IV noob question - can I pull a valve cover (or adjust the valves) without draining the oil? Or am I going to make an Exxon Valdez sized mess if I do so? I ask because I can pull one side at a time on my 911 if I jack up the side of the car I am working on. Don't know if that is possible on a Type IV with its wet sump. |
914_teener |
May 13 2017, 11:08 AM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Am I correct in thinking the oil pressure sender is on the top side of the motor? If so, it is not leaking, the top side is completely dry. That leaves the right side valve cover as a known leak, and the right push rod tubes and the oil cooler as still suspect. Stupid Type IV noob question - can I pull a valve cover (or adjust the valves) without draining the oil? Or am I going to make an Exxon Valdez sized mess if I do so? I ask because I can pull one side at a time on my 911 if I jack up the side of the car I am working on. Don't know if that is possible on a Type IV with its wet sump. Yes. I.d replace the push rod seals and the cover gaskets if the car has been sitting for a while. See also if the breather hose is hooked up. |
Lo-Fi Version | Time is now: 28th April 2024 - 03:53 PM |
