jrblackbox |
Member ![]() ![]() Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None ![]() ![]() |
Nice plate!
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,339 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
(IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
Nice base. Good luck with your explorations! |
arne |
Serial Rescuer of old vehicles... ![]() ![]() ![]() Group: Members Posts: 782 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None ![]() |
A few initial finds. The rear euro lenses and front US lenses are all Hella, not repro. I think they will clean up nicely. The spare tire is the original Continental TT714 on the matching Fuchs, has never hit the ground, no scuffs even in the lug seats. In the rear trunk were a few miscellaneous parts, including a brand new set of 4 original wheel center caps, still in the Porsche boxes.
pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
Nice rescue !
steuspeed |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,010 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest ![]() |
+1 on the plate. I just got the Pacific Wonderland.
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,427 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
That sure seems like a terrific buy. The plate alone makes it work twice what you paid. Keep the pics coming. (IMG:style_emoticons/default/beerchug.gif)
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
arne |
+1 on the plate. I just got the Pacific Wonderland. If - as the seller claimed to me - the plate has been kept current and is still reserved for this car, it is a great addition. I do have the Pacific Wonderland plates on my 911. If the '73 914' plates have expired and someone else has claimed it, I do have a pair of period blue plates I've been hoarding for a potential future use, same ones I had on my 240Z, pictured here. They would also look good on a 914. But I'd rather keep the ones that came with the car, if I can. (IMG:http://www.914world.com/bbs2/uploads_offsite/arnes.stuff.paunix.org-20799-1485886647.2.jpg) |
arne |
Due to other prior commitments, I haven't begun in earnest yet, and probably won't until next Monday. But I have found a few more interesting tidbits:
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,172 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Nice! (IMG:style_emoticons/default/aktion035.gif)
arne |
Yay! Transferred the title today, DMV confirmed that the custom plates are still valid for this car, registration has not lapsed. Great news!
arne |
Spent some time with the car today. Charged a battery and began going through bits. After some prep (oil in cylinders, pull fuel pump relay, ect.), it spins freely, has oil pressure, and also has spark (after replacing the badly corroded points).
Then started checking over the fuel delivery. Total cr@p. The nylon/HDPE lines seem quite brittle and inflexible to me, the hoses appear to be 44 years old, the hose clamps are nasty worm gear type, and the fuel pump in stock location is leaking. Looks like I will need it all. Will probably upgrade pump to a later 2 port style and relocate to the front, since I'm going to have to pull the tank anyway. Trying to make sense of Tangerine's order page now, figuring out what kit I need. |
N_Jay |
Member ![]() ![]() Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None ![]() |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Looks like you are on the right path. Fuel lines should all be replaced, and might as well relocate while you are there. You will probably need to replace much of the rubber, but soaking in glycerin can help some of it if it's not too far gone.
Enjoy the find!! |
arne |
The replacement parts for the fuel delivery are now ordered. New Bosch 2 port pump, and the full package from Chris at Tangerine. Work on the engine is on hold until that stuff all arrives. I will drain the tank in the next few days, but that will be all on that front until the stuff arrives.
Side note - I sent Chris a PM asking if I could call him to ask a question or two, instead he called me within 3 minutes! Great pre-sale support! Other work continues. I've been reassembling all the bits that the prior owner took apart while the car was in storage, primarily lights at this point. I now have all rear lights other than the back-up lights, and all front except high beams and fogs. The high beams are a bit odd, the bulbs are good as they would flash briefly sometimes when I pulled the stalk, but now they don't even do that. More digging.... |
arne |
Jason74914 |
Member ![]() ![]() Group: Members Posts: 76 Joined: 9-January 16 From: Dallas Member No.: 19,544 Region Association: None ![]() |
Welcome to 914 World!
I always love the "it ran great when I stored it" comment. Me: "well then why did you store it?" Ha! Keep us posted. |
Minerva's 914 |
Member ![]() ![]() Group: Members Posts: 379 Joined: 24-December 15 From: Chapel Hill, NC Member No.: 19,489 Region Association: South East States ![]() ![]() |
Fantastic find! I read thru your original post and your moving from the silver ghost to your "ran when parked" barn (storage bin) find and I must say it's tempting me to keep looking for that next fix. As I read your advancement it reminds me of all the trials and tribulations from my own 7 year reclaim on my wife's '73 2.0L (original owner BTW) with the short story thread here Please keep us informed with LOTS of pictures (we love pictures)
(IMG:style_emoticons/default/welcome.png) |
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,749 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
Other work continues. I've been reassembling all the bits that the prior owner took apart while the car was in storage, primarily lights at this point. I now have all rear lights other than the back-up lights, and all front except high beams and fogs. The high beams are a bit odd, the bulbs are good as they would flash briefly sometimes when I pulled the stalk, but now they don't even do that. More digging.... I had a similar issue with the lights, Fuses looked good but must not have been making a good contact. took them all out and polished up the fuses and fuse box connectors and everything works fine now. Check the easy stuff first. |
arne |
Welcome to 914 World! I always love the "it ran great when I stored it" comment. Me: "well then why did you store it?" Ha! Keep us posted. Actually, there was no claim made on how well it ran, just that it did run. I found two manifold pressure sensors under the hood. The original was still bolted to the bracket, but not hooked up at all. Another one was laying loose but was all connected, as if it had been temporarily installed for testing. Best guess is that someone tracked a poor running problem to a possible manifold pressure sensor problem, and installed the new one to see if it fixed it. I'm guessing not. I decided to mount the new one correctly and keep the original just in case. During the process, I found what was likely the true cause, the hose that connects the sensor to the intake plenum was rotted at the manifold end and obviously causing a huge vacuum leak. I corrected that, and then reviewed all the rest of the vacuum hoses as well. Still awaiting the new fuel lines and pump before I can try to start it. |
Lo-Fi Version | Time is now: 9th September 2025 - 06:24 AM |
