arne |
Serial Rescuer of old vehicles... ![]() ![]() ![]() Group: Members Posts: 782 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None ![]() |
Updates:
Brakes - Still not 100% happy with the brakes. As appears to be common, I think there is still some air in there somewhere. Going to need to take another stab at bleeding, perhaps at the pressure regulator. Suspension - Have determined that the front was lowered down to where it truly was riding on the bumpstops. After raising it back up to factory height the ride is much improved. Will order new springs for the rear shortly. Oil leaks - Have determined the left side of the motor is dry, all motor leaks are on the right side. Looks like the bulk is from the valve cover, but the oil cooler just above it also looks a bit wet. Cleaning and driving it to see if I can track down the source(s). New items - shift bushings are pretty sad, will address that soon. Also got the oil temp gauge reconnected, but it seems to work spastically. Once after a rather short test drive, I noticed that it had settled and appeared to be working normally, but was indicating rather hot. Will need to decide if the gauge is accurate, and if so if the engine is running hot. Going to need to check the flappers for function. |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,169 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
For all that is said about George and AA, (much of it true) his little pamphlet 700 Tech Tips is spot on. Four common oil leaks on the passenger side include the oil pressure sender, the oil cooler and the valve cover (both sides), as well as the return tube seals (both sides).
arne |
The cooler doesn't appear to be really wet, but I'll need to locate the pressure sender and check that. Will replace valve cover gaskets as a matter of course. Will probably check the valve adjustment too, no telling when it was last done.
arne |
Re-bled the rear brakes today, I think I got it this time. At least now it doesn't trip the warning light when I stomp on them. Will need to log some miles to see if the pads and rotors will bed properly after they wear off all the rust. If not, might have to deal with pads and rotors to get full brake power.
pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
Great to see another 914 rescued and back in service !
arne |
Brakes - Still not 100% happy with the brakes. As appears to be common, I think there is still some air in there somewhere. Going to need to take another stab at bleeding, perhaps at the pressure regulator. Re-bled the rear brakes today, I think I got it this time. At least now it doesn't trip the warning light when I stomp on them. Will need to log some miles to see if the pads and rotors will bed properly after they wear off all the rust. If not, might have to deal with pads and rotors to get full brake power. Brakes are improving with miles. Starting to feel like they have some power now, and the surface of the disc no longer looks orange-brown. I think this will be ok with more driving.Suspension - Have determined that the front was lowered down to where it truly was riding on the bumpstops. After raising it back up to factory height the ride is much improved. Will order new springs for the rear shortly. Rear springs arrived today and were installed. Big improvement. I'm going to declare the suspension ok for now. |
ConeDodger |
What are you using for tires? That can make The suspension feel rock like as well...
arne |
Tires are 195/65HR15 Toyos, Rob. A bit on the old side, but definitely not what I was feeling. This car had serious suspension issues, now corrected. My guess is that the Konis went on years back, while the car was still fairly fresh. Then as the rear springs sagged out, the answer was to keep lowering the front so that the car sat level. By the time I bought it, both ends were riding on the stops, no travel at all. Now that I have raised it up some and we have suspension travel once again, all is quite well.
arne |
Am I correct in thinking the oil pressure sender is on the top side of the motor? If so, it is not leaking, the top side is completely dry. That leaves the right side valve cover as a known leak, and the right push rod tubes and the oil cooler as still suspect.
Stupid Type IV noob question - can I pull a valve cover (or adjust the valves) without draining the oil? Or am I going to make an Exxon Valdez sized mess if I do so? I ask because I can pull one side at a time on my 911 if I jack up the side of the car I am working on. Don't know if that is possible on a Type IV with its wet sump. |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,268 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
Am I correct in thinking the oil pressure sender is on the top side of the motor? If so, it is not leaking, the top side is completely dry. That leaves the right side valve cover as a known leak, and the right push rod tubes and the oil cooler as still suspect. Stupid Type IV noob question - can I pull a valve cover (or adjust the valves) without draining the oil? Or am I going to make an Exxon Valdez sized mess if I do so? I ask because I can pull one side at a time on my 911 if I jack up the side of the car I am working on. Don't know if that is possible on a Type IV with its wet sump. Yes. I.d replace the push rod seals and the cover gaskets if the car has been sitting for a while. See also if the breather hose is hooked up. |
arne |
Yes, the breather is connected. I've already got a new pair of cover gaskets, will pick up a set of tube seals before I tear into it.
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Check the top side of the oil filter. If there is a puddle on top chances are the leak is cooler related.
arne |
Check the top side of the oil filter. If there is a puddle on top chances are the leak is cooler related. Thanks, that's a good tip. Will look into that when I spend some time in the garage tomorrow. Can the cooler o-rings be replaced with the engine in the car? Or is an engine drop required? |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,057 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Check the top side of the oil filter. If there is a puddle on top chances are the leak is cooler related. Thanks, that's a good tip. Will look into that when I spend some time in the garage tomorrow. Can the cooler o-rings be replaced with the engine in the car? Or is an engine drop required? Guys do it in the car. There's a thread somewhere. I'm sure it's not easy - at least for me. I did it why the engine was out along with some while you are there stuff. |
arne |
Guys do it in the car. There's a thread somewhere. I'm sure it's not easy - at least for me. I did it why the engine was out along with some while you are there stuff. Yeah, I found a Pelican tech article on it. Will probably give it a try. Just do all the leak points at once. |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,930 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
If you're planning to replace the push rod tube seals, that's going to facilitate engine removal (cooling tins and heads need to come off), so that would be the best time to replace the oil cooler seals.
Might also want to check to see if the rear main seal is leaking, and this will also give you the opportunity to check and replace the clutch disc (if needed). |
rhodyguy |
"While I'm in there I might as well..." slippery slope. (IMG:style_emoticons/default/biggrin.gif)
euro911 |
"While I'm in there I might as well..." slippery slope. (IMG:style_emoticons/default/biggrin.gif) Yeah, but why pull the motor out twice? (IMG:style_emoticons/default/poke.gif) |
arne |
Really? I've read (both online and in service manuals) that Type IV push rod tubes can be removed without pulling the heads. Am I missing something here?
mark04usa |
'70 1.7 Tangerine ![]() ![]() Group: Members Posts: 356 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region ![]() ![]() |
Push rod tube seals can be replaced without dropping the engine. It is not a difficult job, just uncomfortable if your car is on jackstands. There is a thread here or on Pelican that covers this repair. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 7th September 2025 - 01:18 PM |
