Common 3 gauges in a center console? |
dgraves |
Mar 27 2017, 10:20 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
The 1974 2.0L that I bought last year had a 911 5-gauge instrument dash installed. The dash has a combo Fuel & Temp gauge, combo Oil Temp & Oil (Druck) Pressure gauge, Speedo, Tach, and Clock. The center console has Amp, Voltmeter, and CHT gauges. I have no idea if the center console was stock or an add on.
I'd like to remove the center console and open up the space, but mount 2 gauges under the dash. So, the question for smarter guys than me...of the Amp, Voltmeter, and CHT, which one do you not "need". This is a great forum for new 914 owners. It's stripped and heading to the paint shop next week. Can't wait. Many thanks. |
falcor75 |
Mar 27 2017, 10:27 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
The temp dial in the center console isnt that oil temp? Not Cht?
Anyway I'd keep the temp gauge and the volt gauge. The volt gauge quickly tells you if you have charging issue, ie a thrown alternator belt. Stock the car came with Volt, Temp and a Clock. |
dgraves |
Mar 28 2017, 08:28 PM
The temp dial in the center console isnt that oil temp? Not Cht? Anyway I'd keep the temp gauge and the volt gauge. The volt gauge quickly tells you if you have charging issue, ie a thrown alternator belt. Stock the car came with Volt, Temp and a Clock. The center console has CHT, Voltmeter, and Amp gauge. I have Oil Temp and Oil Pressure in my dash. Thank you. |
Lo-Fi Version | Time is now: 19th May 2024 - 11:23 AM |
