FS: early 911 cast aluminium rocker covers SOLD |
burton73 |
Mar 27 2017, 10:26 PM
burton73 Group: Members Posts: 3,486 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
From my Hot Rod VW 4 covers, from 1969 911s Ground to clear for Valve adjustment in 914-6 these where on the engine that came in 914-6 #41 when I bought it. $130. Plus freight
rgalla9146 |
Mar 28 2017, 05:34 AM
Advanced Member Group: Members Posts: 4,544 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
PM sent
brant |
Mar 28 2017, 07:00 AM
914 Wizard Group: Members Posts: 11,607 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I need these if they are still Available
they won't fit the later motors but I have the 2.0 that they do fit on which could use them |
burton73 |
Mar 28 2017, 01:25 PM
I need these if they are still Available they won't fit the later motors but I have the 2.0 that they do fit on which could use them These guys weigh in at 8 lbs. I am in Los Angeles, Inglewood CA 90302 Back in the day most guys did not grind these. The factory said to remove the engine to do a valve adjustment. Guys figured to die grind these a little they could get an adjustment done when the engine was in the car. |
brant |
Mar 28 2017, 01:48 PM
so are they still available?
I'm interested with shipping to 80503 I have a motor for them brant |
burton73 |
Mar 28 2017, 04:33 PM
rgalla9146 |
Mar 28 2017, 07:00 PM
Burton 73
Thank you for failing to respond to my PM Rory |
burton73 |
Mar 28 2017, 07:19 PM
Lo-Fi Version | Time is now: 20th April 2024 - 09:47 AM |
