Adjusting Fuel Pressure for Better Running Engine, 1.7 Engine Performance |
R Shaff |
Mar 28 2017, 05:06 AM
Newbie Group: Members Posts: 10 Joined: 16-March 17 From: Charlotte, NC Member No.: 20,936 Region Association: South East States |
I've read some helpful things here while helping with my brother's '72 914. I think I've learned something new and thought I'd share it with you guys.
This car has the original engine and FI system, though the ignition system has been updated and is electronic. The car wasn't running well, and the local shop my brother uses said he should do a carb conversion, costing over $4,000. We looked online and found some good write-ups that recommended keeping the FI system. I've worked on many cars and restored one, so I thought I'd try to get the car running well enough with the original system. The compression and ignition checked out fine. We adjusted the valves (of course). We tested and then replaced 3 injectors, and the CHT sensor. I put the fuel pressure at 28 psi, per spec. Static tests of the manifold pressure sensor came out fine. A cigar smoke test showed no intake leaks. We cleaned and adjusted the TPS, and then finally changed the TPS contact plate and adjusted the arm (when the car just wouldn't run right). All the other components checked out fine, using tests I found online. The result? The engine fired right up, with a good idle. But when driving it lacked power, and the higher the rpm the less it wanted to pull. (Not right for a Porsche.) It felt like the timing wasn't advancing, or that the engine just wasn't getting enough air or gas in the right balance. Other than buying a replacement MPS or computer, I was running out of ideas to try. One of good things about carbs is that they are adjustable. One of the challenging things about these old open-loop FI systems is that they are not really designed to be adjusted much, or at all. Repair is usually a process of testing and replacing components. But this car sure felt like it needed some kind of adjustment. One of the odd things about this car, in my experience, is that the fuel pressure regulator IS adjustable. So that's what we tried, just using seat-of-the-pants performance as the indicator. We dialed the pressure down a turn and things got worse. Then we turned the pressure up, one turn at a time, and voila! As we did the car ran better and better. Now it pulls in the upper ranges like it should, much like it used to. Now we're going to buy a 4th injector of the same type and adjust the pressure again as needed. (Now that we know we can adjust the whole system.) Perhaps that will make it run better still. I haven't read that anywhere(about adjusting fuel pressure to get the engine to run better) so I thought it might help someone else who is struggling with these old Bosch systems. Happy motoring! Richard |
ChrisFoley |
Mar 31 2017, 09:26 AM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
You should be tuning by adjusting the MPS not the FPR.
brant |
Mar 31 2017, 11:56 AM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Rand |
Mar 31 2017, 12:06 PM
I was waiting for this. I don't buy the idea that you can just turn up the fuel pressure above what it's supposed to be and get magic power. If that actually works, something else is out of whack. It needs to be tuned properly. |
Minerva's 914 |
Mar 31 2017, 05:30 PM
Member Group: Members Posts: 378 Joined: 24-December 15 From: Chapel Hill, NC Member No.: 19,489 Region Association: South East States |
I was waiting for this. I don't buy the idea that you can just turn up the fuel pressure above what it's supposed to be and get magic power. If that actually works, something else is out of whack. It needs to be tuned properly. (IMG:style_emoticons/default/agree.gif) I'm in total agreement here. My interest in increasing FP is not to compensate for something being wrong nor to increase power with this adjustment alone but rather something being out of balance. It's possibly out of balance because of the increase in displacement in my rebuild. I don't expect there will be very much of an increase needed and I'm sure it will only be evident at higher RPMs, which I won't see for the next 1200 miles or so after the break-in period however, the factory set the FI for the original engine design and I am bumping up the displacement. So, I will at least play with it and will of course relay any improvement or lack thereof back to the board. I'm not looking for magical increase in power, I'm looking to insure that if the injectors need more fuel at higher RPMs that it's original programing dictated then the FP adjustment will deliver. I want to adjust the feed to match the need. ... then again I could be wrong, it's happened before, though not often (hehehe) unless you ask my wife, she seems to think I'm wrong way more often than I do. Go figure (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 01:21 AM |
