Adjusting Fuel Pressure for Better Running Engine, 1.7 Engine Performance |
R Shaff |
Mar 28 2017, 05:06 AM
Newbie Group: Members Posts: 10 Joined: 16-March 17 From: Charlotte, NC Member No.: 20,936 Region Association: South East States |
I've read some helpful things here while helping with my brother's '72 914. I think I've learned something new and thought I'd share it with you guys.
This car has the original engine and FI system, though the ignition system has been updated and is electronic. The car wasn't running well, and the local shop my brother uses said he should do a carb conversion, costing over $4,000. We looked online and found some good write-ups that recommended keeping the FI system. I've worked on many cars and restored one, so I thought I'd try to get the car running well enough with the original system. The compression and ignition checked out fine. We adjusted the valves (of course). We tested and then replaced 3 injectors, and the CHT sensor. I put the fuel pressure at 28 psi, per spec. Static tests of the manifold pressure sensor came out fine. A cigar smoke test showed no intake leaks. We cleaned and adjusted the TPS, and then finally changed the TPS contact plate and adjusted the arm (when the car just wouldn't run right). All the other components checked out fine, using tests I found online. The result? The engine fired right up, with a good idle. But when driving it lacked power, and the higher the rpm the less it wanted to pull. (Not right for a Porsche.) It felt like the timing wasn't advancing, or that the engine just wasn't getting enough air or gas in the right balance. Other than buying a replacement MPS or computer, I was running out of ideas to try. One of good things about carbs is that they are adjustable. One of the challenging things about these old open-loop FI systems is that they are not really designed to be adjusted much, or at all. Repair is usually a process of testing and replacing components. But this car sure felt like it needed some kind of adjustment. One of the odd things about this car, in my experience, is that the fuel pressure regulator IS adjustable. So that's what we tried, just using seat-of-the-pants performance as the indicator. We dialed the pressure down a turn and things got worse. Then we turned the pressure up, one turn at a time, and voila! As we did the car ran better and better. Now it pulls in the upper ranges like it should, much like it used to. Now we're going to buy a 4th injector of the same type and adjust the pressure again as needed. (Now that we know we can adjust the whole system.) Perhaps that will make it run better still. I haven't read that anywhere(about adjusting fuel pressure to get the engine to run better) so I thought it might help someone else who is struggling with these old Bosch systems. Happy motoring! Richard |
TheCabinetmaker |
Apr 1 2017, 05:58 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The cap'n would have thoroughly chewed ass here. If your guessing at the pressure it might be 35 lbs or even 40. That will quickly destroy parts of your system. Injectors will be the first to suffer. They will start leaking internally flooding the combustion chamber, and possibly washing the cylinders and damaging the rings. Then they can leak externally and possibly burn your car to the ground. Many very knowledgeable people here have told you it's a bad thing, but you continue to ignore them. Good luck with car.
R Shaff |
Apr 2 2017, 04:16 PM
The cap'n would have thoroughly chewed ass here. If your guessing at the pressure it might be 35 lbs or even 40. That will quickly destroy parts of your system. Injectors will be the first to suffer. They will start leaking internally flooding the combustion chamber, and possibly washing the cylinders and damaging the rings. Then they can leak externally and possibly burn your car to the ground. Many very knowledgeable people here have told you it's a bad thing, but you continue to ignore them. Good luck with car. Sorry Captain, but you won't be hearing any fire engines racing to this house. (I'm not an idiot. I used a gauge when I first adjusted the pressure, so I saw how sensitive the adjustments are. It was at 32 when I started. I turned it down to 28, and the engine wouldn't pull at upper rpms. I turned it back up a bit, probably in the 30-32 psi range, and it ran great. No fires. And clearly the ignition advance is working or it would not run well at higher rpm.) That's all. I said the car was running well. Still is. I was just putting my experience out there in case it helps someone else. For those of you who still think I should adjust the MPS, I'm eager to hear how you would do that. Mine holds a vacuum fine, and it passes the static electronic tests. And again the car is running pretty well. I'm reluctant to tear into the complex and fragile MPS when things are working, but I'm open to suggestions (like the variable resistor idea on the CHT). Thx. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:27 PM |
