Rear hub conversion..., aligning the holes... |
falcor75 |
Mar 28 2017, 11:28 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I had two rear hubs done but none of the holes for the brake disc mounting screws were lined up and the hackjob of drilling and countersinking new holes in the brake disc was something I didnt like.
The mounting holes in the hub are oriented 180 degrees apart from what I can tell. The holes in the 914-6 brake disc are more like 175/185 degrees apart. Is there any particular way that is better than the others for orientation of the hub vs the brake disc? I want to be able to give as clear instructions as possible to the machine shop. (IMG:style_emoticons/default/confused24.gif) |
jmitro |
Mar 29 2017, 01:09 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
no it won't. installing the wheel with 4 (or 5) lug nuts/bolts will properly seat the rotor
mgphoto |
Mar 29 2017, 02:24 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
no it won't. installing the wheel with 4 (or 5) lug nuts/bolts will properly seat the rotor The disk will be held in place by the sandwich of wheel and drive. Trust your life to that, factory didn't. Early cars have no centering rings. Building a car for the "look" that is fine but these cars were meant to be driven, compromising that is unsafe especially for the next guy you sell it to. Mike |
Lo-Fi Version | Time is now: 16th May 2024 - 10:28 PM |
