Rear hub conversion..., aligning the holes... |
falcor75 |
Mar 28 2017, 11:28 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I had two rear hubs done but none of the holes for the brake disc mounting screws were lined up and the hackjob of drilling and countersinking new holes in the brake disc was something I didnt like.
The mounting holes in the hub are oriented 180 degrees apart from what I can tell. The holes in the 914-6 brake disc are more like 175/185 degrees apart. Is there any particular way that is better than the others for orientation of the hub vs the brake disc? I want to be able to give as clear instructions as possible to the machine shop. (IMG:style_emoticons/default/confused24.gif) |
Spoke |
Mar 29 2017, 04:36 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I had the same issue using 911 rotors with redrilled 914 hubs. Holes in the wrong location.
Ended up using the holes in the rotors to drill and tap the hubs for the new hole locations. Problem solved. |
Lo-Fi Version | Time is now: 16th May 2024 - 11:06 PM |
