Rear hub conversion..., aligning the holes... |
falcor75 |
Mar 28 2017, 11:28 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I had two rear hubs done but none of the holes for the brake disc mounting screws were lined up and the hackjob of drilling and countersinking new holes in the brake disc was something I didnt like.
The mounting holes in the hub are oriented 180 degrees apart from what I can tell. The holes in the 914-6 brake disc are more like 175/185 degrees apart. Is there any particular way that is better than the others for orientation of the hub vs the brake disc? I want to be able to give as clear instructions as possible to the machine shop. (IMG:style_emoticons/default/confused24.gif) |
mgphoto |
Mar 29 2017, 12:17 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
If you don't put the screws, any of the disks could move on assembly making that wheel out of balance.
I decided to source original parts instead of "modified" ones. Mike |
mepstein |
Mar 29 2017, 04:31 PM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
If you don't put the screws, any of the disks could move on assembly making that wheel out of balance. I decided to source original parts instead of "modified" ones. Mike Move where? What will two little screws do that five large studs torqued down to 90 ft lbs. won't? |
mgphoto |
Mar 29 2017, 04:37 PM
If you don't put the screws, any of the disks could move on assembly making that wheel out of balance. I decided to source original parts instead of "modified" ones. Mike Move where? What will two little screws do that five large studs torqued down to 90 ft lbs. won't? "On assembly" you trust some mook at Discount Tire Express to make sure your disks are centered ? You might take the time to do it right. Mike |
mepstein |
Mar 29 2017, 05:00 PM
If you don't put the screws, any of the disks could move on assembly making that wheel out of balance. I decided to source original parts instead of "modified" ones. Mike Move where? What will two little screws do that five large studs torqued down to 90 ft lbs. won't? "On assembly" you trust some mook at Discount Tire Express to make sure your disks are centered ? You might take the time to do it right. Mike I usually do it on the lift at our Porsche shop. |
Lo-Fi Version | Time is now: 16th May 2024 - 11:32 PM |
