Amp Location, Where did you put yours..... |
HerdofCrickets |
Mar 28 2017, 12:21 PM
Member Group: Members Posts: 68 Joined: 23-September 16 From: Overland Park, KS Member No.: 20,423 Region Association: None |
The guys at 914Rubber were nice enough to send me the subwoofer box for the passenger floor, and will also be sending the retrofitted speaker mounts in the next week or two. My amp will arrive tomorrow.... Question is... where did you all put your amp's? I assume the back trunk is best and it is small enough to still allow for storage of the top, but what did you do to keep it from sliding around? building a box? I hate to actually screw it into the truck... |
VaccaRabite |
Mar 30 2017, 08:20 AM
En Garde! Group: Admin Posts: 13,445 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I have a small 70watt amp that I had attached on the underside of the dash. Modern digital amps are so small they can go almost anywhere.
Zach |
HerdofCrickets |
Mar 30 2017, 05:23 PM
mgp4591 |
Mar 31 2017, 01:30 PM
914 Guru Group: Members Posts: 5,376 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I have a small 70watt amp that I had attached on the underside of the dash. Modern digital amps are so small they can go almost anywhere. Zach 70 watt? And I have a 1200 watt.... hmmm.... might need to downsize that one. Small amps are for sissies... more power usually means better speaker response equaling better sound overall. If you want less volume, there's a knob for that! (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 22nd May 2024 - 01:14 PM |
