> Headlight electrical question, bad ground
vin man
post Mar 29 2017, 10:37 AM
On the driver side of my 71, the low beam comes on, but just barely. High beam works fine (Both beam are good on passenger side).
I have replaced the bulb, but still have the issue. While I suspect a bad ground, if that was the case, wouldn't the high beam not work properly has well?
According to electrical diagram, there is only one ground wire coming out of the headlight.
Anyone have advice on how to troubleshoot? I've checked the ground connection at the body and it is good.
Thanks.
- Lo-Fi Version Time is now: 2nd September 2026 - 05:40 PM
