Headlight electrical question, bad ground |
vin man |
Mar 29 2017, 10:37 AM
Member Group: Members Posts: 178 Joined: 19-February 10 From: Gilbert, Arizona USA Member No.: 11,380 Region Association: Southwest Region |
On the driver side of my 71, the low beam comes on, but just barely. High beam works fine (Both beam are good on passenger side).
I have replaced the bulb, but still have the issue. While I suspect a bad ground, if that was the case, wouldn't the high beam not work properly has well? According to electrical diagram, there is only one ground wire coming out of the headlight. Anyone have advice on how to troubleshoot? I've checked the ground connection at the body and it is good. Thanks. |
Dave_Darling |
Mar 29 2017, 12:50 PM
What kind of voltage are you seeing across each filament?
Is it possible that the low beam is grounding through the high beam rather than through the ground wire? Are the wires plugged in correctly? --DD |
vin man |
Mar 29 2017, 01:51 PM
What kind of voltage are you seeing across each filament? Is it possible that the low beam is grounding through the high beam rather than through the ground wire? Are the wires plugged in correctly? --DD I'm no expert, but I suspect that the situation is exactly as you describe. It is not grounding properly, but instead through the high beam. How would I measure the voltage through the individual filaments? Would that be take reading on yellow wire and ground, then white wire and ground? The low beam does come on, but very very faint. |
Lo-Fi Version | Time is now: 18th May 2024 - 07:51 PM |
