Headlight electrical question, bad ground |
vin man |
Mar 29 2017, 10:37 AM
Member Group: Members Posts: 178 Joined: 19-February 10 From: Gilbert, Arizona USA Member No.: 11,380 Region Association: Southwest Region |
On the driver side of my 71, the low beam comes on, but just barely. High beam works fine (Both beam are good on passenger side).
I have replaced the bulb, but still have the issue. While I suspect a bad ground, if that was the case, wouldn't the high beam not work properly has well? According to electrical diagram, there is only one ground wire coming out of the headlight. Anyone have advice on how to troubleshoot? I've checked the ground connection at the body and it is good. Thanks. |
jcd914 |
Mar 30 2017, 12:02 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Compare the wires on each headlight bulb. The white and brown wires are probably connected differently on each headlight.
Jim |
Lo-Fi Version | Time is now: 26th May 2024 - 02:36 AM |
