Headlight electrical question, bad ground |
vin man |
Mar 29 2017, 10:37 AM
Member Group: Members Posts: 178 Joined: 19-February 10 From: Gilbert, Arizona USA Member No.: 11,380 Region Association: Southwest Region |
On the driver side of my 71, the low beam comes on, but just barely. High beam works fine (Both beam are good on passenger side).
I have replaced the bulb, but still have the issue. While I suspect a bad ground, if that was the case, wouldn't the high beam not work properly has well? According to electrical diagram, there is only one ground wire coming out of the headlight. Anyone have advice on how to troubleshoot? I've checked the ground connection at the body and it is good. Thanks. |
vin man |
Mar 30 2017, 09:04 PM
Test above completed.
With LOW beams on, I have about 12 Volts on each side of Fuse 3, but 0 volts across fuse 4. I will need to remove the fuse block and check the connection because there is supposed to be a jumper between the fuse 3 and 4 on the feed side (according to my diagram which I seem to understand more each time I look at it). My concern is that, according to the diagram, the feed should be on fuse 4, and the jumper goes to fuse 3. Will remove and inspect. Still looking for any other guidance. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:28 PM |
