914-6 #41 -Let's Rock E, well 41 is done and delivered, Video and drone vid very soon |
burton73 |
Apr 2 2017, 12:08 PM
burton73 Group: Members Posts: 3,508 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Eric @ PMB was kind enough to pick up my primo fresh 3.0 with 3.2 heads with custom cam with 46 PMO’s blueprinted and balanced to race tolerances from Scott Kinder at Kindersport in Oakland, CA area.
The engine should be good for 240HP matted to a 901 Transmission Rebuilt 2000 Miles ago by Performance Haus in 1980 with hand polished close ratio 906 gears Late model "side shift" linkage, Adjustable 19mm front sway bar with Teflon bushings, Bilstein Carrera RS front struts, Bilstein rear shocks, Modified front early 911S brakes and PMB vented 914-6 rears. Done by the Maestro Eric himself. Lots of more goodies on the car first reworked in the 70’s. It was a project car of a guy that worked at a OC local Porsche speed shop. This has always been a California car. It has never seen salt and has no rust. This car has been at PMB for a couple of years waiting for the Engine. Number 41 is from what we know to be the 30th. 914-6 in production. I am sure I will hear something from someone that knows more. This car has not been on the road in CA since the early 80s when it would not pass smog. It had a 69S engine when I bought it. The 911 engine is really a thing of ART, well all Porsche/VW parts when clean and polished /painted are art. The cam timing is critical. Scott sent me several pictures from the build. Eric’s work at PMB is also a work of art. More to come! Bob Burton |
burton73 |
Aug 9 2017, 01:53 PM
PMB put the stacks on my PMOs. The PO had non 914-6 air cleaner on it and I am going with the same set up. Will show more. Also the trans after PMB re freshened it. I got a NOS case from AA 9 years ago and it looked great in its Porsche box but after PMB inspected it had a cracked bearing seating area so we are trashing (recycling it)
I got it in the first place, as the old Transmission case looked pickled from what I guess was engine cleaner. This was the info on the transmission. From the PO. “Transmission Rebuilt 2000 Miles ago by Performance Haus, , Hand polished close ratio 906 gears Late model "side shift" linkage” PMB found that it needed more than just new seals and gaskets. You really have to CK out everything on a restoration. Even N.O.S. parts or you can be S.O.L. That 2,000 miles was 30 years ago. Bob B |
Lo-Fi Version | Time is now: 28th April 2024 - 05:57 PM |
