> Cover/Close The Defroster Vent Holes, For you guys without heat
7TPorsh
post Apr 4 2017, 11:32 AM
7T Porsh
My car doesn't have the front defroster vents and control boxes. I have a header so out with all the heater stuff. I can manage covering the bulkhead holes but what are the solutions for the top dash defroster holes? The long holes on the top of the dash.
I want to plug them and cover with 914rubber vinyl. Have to get vinyl without the cutouts.
Anyone found a good solution?
Rob-O
post Apr 4 2017, 01:22 PM
You could just cut pieces of metal out using some hand shears and tape/glue/weld/rivet them over the holes. Something that's going to help them stay put.
As far as the vinyl, I'll bet Mark at 914Rubber would send you a piece of vinyl that didn't have the cuts made for the defroster vents. Or you can do what I did, go down to the nearest JoAnn Fabrics and buy some black vinyl. Then use the old piece as a template for the new piece. Just don't cut the areas for your now gone defroster vents.
Rand
post Apr 4 2017, 01:34 PM
Cross Member
On my first 914, I taped over the holes with aluminum tape, then covered with burlap for something different.
- Lo-Fi Version Time is now: 6th July 2025 - 01:47 AM
