Lit up my rear reflector lens even more!, Whacha think now? |
oakdalecurtis |
Apr 13 2017, 11:56 PM
Oakdalecurtis Group: Members Posts: 1,324 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
speed metal army |
Apr 14 2017, 12:16 AM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
I think I can see that from Canada! (IMG:style_emoticons/default/biggrin.gif)
Looks pretty cool, and the extra visibility cant hurt for sure. (IMG:style_emoticons/default/shades.gif) |
SixerJ |
Apr 14 2017, 12:50 AM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
I like it!
mgp4591 |
Apr 14 2017, 02:35 AM
914 Guru Group: Members Posts: 5,368 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Looks great! More details on the LED strip and how you installed it please...
Tbrown4x4 |
Apr 14 2017, 02:59 AM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Should have wired it to the brake lights!
sb914 |
Apr 14 2017, 05:16 AM
Surf Guru Group: Members Posts: 4,296 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Looks bright
billh1963 |
Apr 14 2017, 05:43 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
PlaysWithCars |
Apr 14 2017, 10:56 AM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Ditto. Anyway to put two strips in there? One low power and the other brighter one connected to the brake circuit? It would make a rocking third brake light. |
oakdalecurtis |
Apr 14 2017, 11:06 AM
If you go on Amazon and search LED strip lights, you will easily find them, and they are cheap! The lights come on a roll and can be cut to any length, then just solder on your own wire leads to the strip. The strip's back is self adhesive, so just stick the light section on the car back panel. The light strip is only a quarter inch wide and a tenth of an inch high. Dremel carve a groove in the reflector supports where needed to allow the light strip to pass under. Drill a hole where needed in the car back panel to allow the wires to pass into the trunk and connect them to ground and one of the parking light leads. LED lights are polarity sensitive, so make sure you hook the positive side to the parking light lead. Pretty easy stuff all in all.
Apr 14 2017, 11:07 AM
I don't care for it. But then, I don't really like the reflector on a 914 to start with.
That said, anything that adds visibility to our little tiny cars is a good thing. --DD |
Andyrew |
Apr 14 2017, 11:40 AM
I like it for brake lights! Not for running lights, its a little bright for that.
twistedstang |
Apr 14 2017, 12:46 PM
Member Group: Members Posts: 220 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None |
SO.O.C914er |
Apr 14 2017, 01:36 PM
Senior Member Group: Members Posts: 1,236 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California |
I like it and I have the reflecter on my car. But agree would want it working with the brake lights. (IMG:style_emoticons/default/driving.gif)
burton73 |
Apr 14 2017, 01:55 PM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I like it on your car. 75,76 cars will take this mod and look good. On older 914’s I would say no. For sure brake lights as most drivers are dicks. (IMG:style_emoticons/default/sunglasses.gif)
rjames |
Apr 14 2017, 02:10 PM
I'm made of metal Group: Members Posts: 3,920 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Did you use the red or white LEDs?
oakdalecurtis |
Apr 14 2017, 03:17 PM
Did you use the red or white LEDs? Used white lights, the reflector lens makes it more than red. And it's not quite as bright at night as the pics look, the camera just sucks up the light. You could lay in 2 or 3 light strips wired as you please, one to parking lamps and others to brakes. The strips are only a quarter inch wide each. Since I have a high third mounted strobe brake light on order, I went with the lens as a running light. |
ConeDodger |
Apr 14 2017, 03:19 PM
Apex killer! Group: Members Posts: 23,574 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I don't care for it. But then, I don't really like the reflector on a 914 to start with. That said, anything that adds visibility to our little tiny cars is a good thing. --DD (IMG:style_emoticons/default/agree.gif) |
djway |
Apr 14 2017, 05:53 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
I think it is cool and I have added it to my tooo doooo list (IMG:style_emoticons/default/smile.gif)
pvollma |
Apr 14 2017, 10:04 PM
Member Group: Members Posts: 205 Joined: 12-May 13 From: Camp Hill, PA Member No.: 15,862 Region Association: MidAtlantic Region |
I like it and I have the reflecter on my car. But agree would want it working with the brake lights. (IMG:style_emoticons/default/driving.gif) Here's how mine look connected to the brake lights: Here's how they were attached to the reflector: I believe there has been some discussion here and on LED vendor sites that the LED color should match the lens color for the best performance -- the ones I used are red. |
EdwardBlume |
Apr 14 2017, 10:28 PM
Can you add the notes from "Close Encounters of the 3rd Kind?" and make it blink?
(IMG:style_emoticons/default/very_first_smiley[1].gif) (IMG:style_emoticons/default/very_first_smiley[1].gif) (IMG:style_emoticons/default/very_first_smiley[1].gif) (IMG:style_emoticons/default/very_first_smiley[1].gif) (IMG:style_emoticons/default/very_first_smiley[1].gif) just kidding. Out in the fog you might be the wisest 914 out there.... |
Lo-Fi Version | Time is now: 3rd May 2024 - 08:06 PM |
