WTB 914 Parts |
WTB 914 Parts |
aturboman |
Apr 14 2017, 04:10 PM
Member Group: Members Posts: 135 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
I'm looking for the following 914 bits:
Brake reservoir feed lines; these are the white plastic lies with the metal ends. Must be intact and undamaged. Rear upper targa bar molding; this is the long thin aluminum molding going between the sail moldings above the engine compartment. 2 stock rear upper shock spring mounts or "hats". I'd love NOS on all these but I'm sure I'll have to restore what I can get, so please no basket case parts. Let me know what you have and cost. Thanks |
bdstone914 |
Apr 14 2017, 08:41 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I'm looking for the following 914 bits: Brake reservoir feed lines; these are the white plastic lies with the metal ends. Must be intact and undamaged. Rear upper targa bar molding; this is the long thin aluminum molding going between the sail moldings above the engine compartment. 2 stock rear upper shock spring mounts or "hats". I'd love NOS on all these but I'm sure I'll have to restore what I can get, so please no basket case parts. Let me know what you have and cost. Thanks I have all of those parts. Not NOS bu I have a bunch and can sort out the best ones. I this for a -6? I know early 914 had a smaller diameter springs that needed different perches. The big spring will not work in the small perch but the small spring should work in the big perch. Bruce |
aturboman |
Apr 20 2017, 10:46 AM
Hi Bruce sent you a PM, thanks
Lo-Fi Version | Time is now: 23rd April 2024 - 11:47 PM |
