Calling all 914/6 owners past & present, Need advice |
GaroldShaffer |
Jun 30 2003, 09:06 PM
You bought another 914? Group: Benefactors Posts: 7,622 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
It's been 3 1/2 LONG years since I sold my beloved 73 914 2.0 (IMG:style_emoticons/default/headbang.gif) to help with a down payment on our new house. In two years I will turn 40 and plan to be a 914 owner once again (IMG:style_emoticons/default/clap56.gif) .
silver six |
Jul 3 2003, 12:43 PM
Member Group: Members Posts: 203 Joined: 3-February 03 From: San Bruno, California Member No.: 227 |
To second what Seanery said, the 3.0 and the 3.2 are likely the best conversion engines available for the 914. Brad has confirmed this sentiment many times. This is why they work better than other engines:
1. Durability: The pre 3.0 engines (the 2.7, the 2.4, etc.) are much less reliable than the 3.0 and 3.2 liters. 2. Ease of Installation: The 3.0/3.2 engines are just as easy to install as the earlier engines and much easer to install than larger and newer engines (3.6, 3.8, etc.). Also remember with larger engines you must go with stronger trannys. With the 3.0/3.2 you can get away with the 914's stock 901 tranny (although I personally would not recommend this tranny as a long-term solution; I think Brad would back me up on this). 3. Cost: Although a little more expensive, the 3.0/3.2 engines are similarly priced as compared to earlier engines. The 3.0/3.2 cost about the same to maintain as earlier engines. The 3.0/3.2 are significantly less expensive to buy and maintain as compared to subsequent larger engines. Of course, if cost is no object then the larger engines (3.6, 3.8 etc.) would be preferable. 4. Subjective Feel: The fuel injected 3.0/3.2 starts right up and idles smoothly and continues to do so all the way till warm-up. These engines are very well behaved while producing more power than their predecesors. They also make great sounds. Douglas |
Lo-Fi Version | Time is now: 19th May 2024 - 07:18 AM |
