Replace 901 transmission, 1973 914 transmission removal |
tbone1819 |
Apr 18 2017, 09:05 AM
Newbie Group: Members Posts: 26 Joined: 1-February 17 From: Lynbrook NY Member No.: 20,800 Region Association: North East States |
How hard is it to replcae? Do you need to remove the engine as well?
rjames |
Apr 18 2017, 09:38 AM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
No need to drop the engine.
Step by step can be found here on Pelican's site: http://www.pelicanparts.com/techarticles/9...ch_replace1.htm |
Mark Henry |
Apr 18 2017, 10:03 AM
Sometimes it's just as easy to drop the engine and trans together. If you want to do some cleanup, valve adjustment, etc., on the engine just drop the whole thing.
johnhora |
Apr 18 2017, 10:36 AM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Sometimes it's just as easy to drop the engine and trans together. If you want to do some cleanup, valve adjustment, etc., on the engine just drop the whole thing. (IMG:style_emoticons/default/agree.gif) You already have the time consuming parts disconnected which are the axles and shifter...two more bolts, fuel line, and wiring harness and your done... and it's easier to remove and reconnect the tranny and engine back together on the ground... |
tbone1819 |
Apr 22 2017, 07:15 AM
No need to drop the engine. Step by step can be found here on Pelican's site: http://www.pelicanparts.com/techarticles/9...ch_replace1.htm Thanks!!!!!!! |
Lo-Fi Version | Time is now: 17th May 2024 - 10:59 PM |
