Resto-Thread: '73 Marathon Blue 2.0 |
914_7T3 |
Apr 21 2017, 01:28 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,846 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
I have been on 914 World for just a few weeks and with the knowledge and support of everyone was able to get up to speed quickly on values and things to look out for. when considering a vehicle to purchase.
I just acquired this matching numbers '73 Marathon Blue 2.0 up in NorCal on Wednesday. Straight car with a strong motor and minimal rust issues. Fuel lines and pump have already replaced and rear suspension and brakes were done about 5,000 miles ago back in 2012. The required rust repairs of significance will entail a partial front trunk pan and minor hell hole repair so in the grand scheme of things a great starting point. My plan is to get her tuned up, fix oils leaks and anything else of concern while I drive her over the summer. Once fall/winter hits I would like to do a full repaint down to the metal. Special shout out to Arne as well as Craig from Camp 914 for the behind the scenes consults. Also shout out to John at Hayes European in Santa Cruz for the PPI! Wish me luck! |
914_7T3 |
May 3 2017, 09:31 PM
The full service up at TRE Motorsports has been going very well overall. So far dealing with a lot of minor issues,
valve adjust filters new plugs clean fuses and headlight relay replace headlights with a new set of H4s clutch adjust fuel line & pump, suspension and brakes all found to be in good condition A large oil leak has been found under the plastic cover of the side shifter. The seal most likely has been leaking for a while as the cup is full of oil. Needless to say, seals will be replaced in the morning and shift bushings and linkage will also be verified. If all goes well, she will be good to go by the end of the day. Overall, more mechanically sound than I anticipated. Hopefully there will be no surprises before they finish. |
Lo-Fi Version | Time is now: 28th March 2024 - 12:15 PM |
