Ford Solenoid Hot Start installation instructions, Mark Henry's method |
Mark Henry |
Apr 24 2017, 05:12 AM
Because this comes up so often I decided to make a tutorial on how I install the Ford solenoid.
The Ford solenoid fixes the common hot start problem of Bosch starter solenoid and it also reduces the load on the ignition switch. Although these instructions are for the 914 all aircooled VW's and Porsche often suffer from this problem and with minor changes this can be done to any car. The issue occurs because the Bosch starter solenoid needs a full 9 volts to kick in. The combination of age, heat, corrosion, many connectors, a small ignition switch and wiring running to the dash and back can degrade the volts to less than the 9V required. The Ford solenoid only needs about 3 volts for the 12V version and even less for the 6V which for our purpose works no problem. My installation drills no holes in the car, not a single factory wire is cut, no in-line fuses, fully reversible and simple with no added bullshit. Please this is not a discussion on if you prefer the wimpy (IMO) Bosch horn relay, want to cut and hack in a new wire or believe throat singing Vajrayana chants is a better method, start you're own thread. Of course as with any electrical trouble shooting the first order of business is always clean all of your grounds and make sure the chassis to transmission ground strap is in place and in good condition. I'll start right away with the money shot of the completed installation to show how clean this can be done. Attached image(s) |
Mark Henry |
Aug 7 2017, 08:56 PM
One fail point I was told, but have no direct proof (anecdotal) was that a cheap Chinese relay had failed. That why I recommend the "Standard" brand of relay's.
I've never had a Standard relay fail other than the one that fell apart from severe corrosion. This was after 8 years of winter service on heavily salted roads. |
914Toy |
Jan 2 2018, 05:22 PM
Senior Member Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
One fail point I was told, but have no direct proof (anecdotal) was that a cheap Chinese relay had failed. That why I recommend the "Standard" brand of relay's. I've never had a Standard relay fail other than the one that fell apart from severe corrosion. This was after 8 years of winter service on heavily salted roads. Hi Mark, Surprised to see that no ground wire is needed to be attached to the non used terminal in your application of the Ford relay switch? |
Mark Henry |
Jan 2 2018, 07:05 PM
One fail point I was told, but have no direct proof (anecdotal) was that a cheap Chinese relay had failed. That why I recommend the "Standard" brand of relay's. I've never had a Standard relay fail other than the one that fell apart from severe corrosion. This was after 8 years of winter service on heavily salted roads. Hi Mark, Surprised to see that no ground wire is needed to be attached to the non used terminal in your application of the Ford relay switch? Because the metal bracket on the solenoid is bolted to the starter mounting stud, there's your ground for the solenoid. (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:07 PM |
