Ford Solenoid Hot Start installation instructions, Mark Henry's method |
Mark Henry |
Apr 24 2017, 05:12 AM
Because this comes up so often I decided to make a tutorial on how I install the Ford solenoid.
The Ford solenoid fixes the common hot start problem of Bosch starter solenoid and it also reduces the load on the ignition switch. Although these instructions are for the 914 all aircooled VW's and Porsche often suffer from this problem and with minor changes this can be done to any car. The issue occurs because the Bosch starter solenoid needs a full 9 volts to kick in. The combination of age, heat, corrosion, many connectors, a small ignition switch and wiring running to the dash and back can degrade the volts to less than the 9V required. The Ford solenoid only needs about 3 volts for the 12V version and even less for the 6V which for our purpose works no problem. My installation drills no holes in the car, not a single factory wire is cut, no in-line fuses, fully reversible and simple with no added bullshit. Please this is not a discussion on if you prefer the wimpy (IMO) Bosch horn relay, want to cut and hack in a new wire or believe throat singing Vajrayana chants is a better method, start you're own thread. Of course as with any electrical trouble shooting the first order of business is always clean all of your grounds and make sure the chassis to transmission ground strap is in place and in good condition. I'll start right away with the money shot of the completed installation to show how clean this can be done. Attached image(s) |
HalfMoon |
Jan 25 2018, 05:42 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
So I've run across a (self created) problem and I wonder if Mark might chime in for a solution?
Previously I had wired in a Ford relay on my sbc converted 914 with a standard alternator per Mark's diagram (an-noted below) as I had been experiencing the well known "hot start" problem. The fix worked great! Then I decided to add a track "kill switch" mounted where track workers can get to it in an emergency and therein lies my problem. When I wire it up per the manufacturer's directions (my diagram below), it works great with one exception...my hot start problem has returned. Anyone got any idea's? Marks diagram (an-noted) with no kill switch. Hot start problem solved. My diagram including addition of a kill switch. Hot start problem returns |
Mark Henry |
Aug 4 2018, 10:24 AM
So I've run across a (self created) problem and I wonder if Mark might chime in for a solution? Previously I had wired in a Ford relay on my sbc converted 914 with a standard alternator per Mark's diagram (an-noted below) as I had been experiencing the well known "hot start" problem. The fix worked great! Then I decided to add a track "kill switch" mounted where track workers can get to it in an emergency and therein lies my problem. When I wire it up per the manufacturer's directions (my diagram below), it works great with one exception...my hot start problem has returned. Anyone got any idea's? Marks diagram (an-noted) with no kill switch. Hot start problem solved. My diagram including addition of a kill switch. Hot start problem returns Right away I can see the battery wired wrong, battery + goes to the starter big post, in your configuration the alternator + wire also goes to the starter big post. Kill switch shouldn't be wired into the starter, unless it's a battery disconnect, then it should be wired inline on the big battery cable. This needs to have no other wires between the battery + post and the disconnect in. All factory + wires should be after the disconnect out. Only exception to above is some will run a seperate wire before the disconnect (direct to + post) for the radio clock. |
HalfMoon |
Aug 4 2018, 03:10 PM
So I've run across a (self created) problem and I wonder if Mark might chime in for a solution? Previously I had wired in a Ford relay on my sbc converted 914 with a standard alternator per Mark's diagram (an-noted below) as I had been experiencing the well known "hot start" problem. The fix worked great! Then I decided to add a track "kill switch" mounted where track workers can get to it in an emergency and therein lies my problem. When I wire it up per the manufacturer's directions (my diagram below), it works great with one exception...my hot start problem has returned. Anyone got any idea's? Marks diagram (an-noted) with no kill switch. Hot start problem solved. My diagram including addition of a kill switch. Hot start problem returns Right away I can see the battery wired wrong, battery + goes to the starter big post, in your configuration the alternator + wire also goes to the starter big post. Kill switch shouldn't be wired into the starter, unless it's a battery disconnect, then it should be wired inline on the big battery cable. This needs to have no other wires between the battery + post and the disconnect in. All factory + wires should be after the disconnect out. Only exception to above is some will run a seperate wire before the disconnect (direct to + post) for the radio clock. Thanks for the reply- Unfortunately, when I ran it with the Alt wire to the to the starter solenoid the kill switch failed to work and would not cut off the running car as it should. The only way I was able to make it work was to connect the Alt. wire to the switched side of the kill switch but then the hot start problem reappeared (either that or a new problem). |
Spoke |
Aug 12 2018, 12:08 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
So I've run across a (self created) problem and I wonder if Mark might chime in for a solution? Previously I had wired in a Ford relay on my sbc converted 914 with a standard alternator per Mark's diagram (an-noted below) as I had been experiencing the well known "hot start" problem. The fix worked great! Then I decided to add a track "kill switch" mounted where track workers can get to it in an emergency and therein lies my problem. When I wire it up per the manufacturer's directions (my diagram below), it works great with one exception...my hot start problem has returned. Anyone got any idea's? Marks diagram (an-noted) with no kill switch. Hot start problem solved. My diagram including addition of a kill switch. Hot start problem returns Right away I can see the battery wired wrong, battery + goes to the starter big post, in your configuration the alternator + wire also goes to the starter big post. Kill switch shouldn't be wired into the starter, unless it's a battery disconnect, then it should be wired inline on the big battery cable. This needs to have no other wires between the battery + post and the disconnect in. All factory + wires should be after the disconnect out. Only exception to above is some will run a seperate wire before the disconnect (direct to + post) for the radio clock. Thanks for the reply- Unfortunately, when I ran it with the Alt wire to the to the starter solenoid the kill switch failed to work and would not cut off the running car as it should. The only way I was able to make it work was to connect the Alt. wire to the switched side of the kill switch but then the hot start problem reappeared (either that or a new problem). Not sure how the internals of the kill switch work but the battery should never be removed from the alternator when the engine is running. Modern cars use high power zener diodes as rectifiers in the alternator to snub the inductive kick if the battery is removed from the alternator when running. Almost any electronics in the vehicle could be damaged by the inductive kick. Automotive test specification ISO 7637-2 pulse 5 is a killer pulse. This pulse is 100V for about 1/2 a second and simulates disconnecting the battery from the alternator. If you're looking to protect the car from being stolen, you might want to try putting a switch in series with the spark unit, ECU, or the fuel pump. On my 930, I have a tiny toggle switch in series with the fuel pump relay. You can push the car or crank it all day and it won't start. |
HalfMoon |
Aug 12 2018, 10:06 PM
So I've run across a (self created) problem and I wonder if Mark might chime in for a solution? Previously I had wired in a Ford relay on my sbc converted 914 with a standard alternator per Mark's diagram (an-noted below) as I had been experiencing the well known "hot start" problem. The fix worked great! Then I decided to add a track "kill switch" mounted where track workers can get to it in an emergency and therein lies my problem. When I wire it up per the manufacturer's directions (my diagram below), it works great with one exception...my hot start problem has returned. Anyone got any idea's? Marks diagram (an-noted) with no kill switch. Hot start problem solved. My diagram including addition of a kill switch. Hot start problem returns Right away I can see the battery wired wrong, battery + goes to the starter big post, in your configuration the alternator + wire also goes to the starter big post. Kill switch shouldn't be wired into the starter, unless it's a battery disconnect, then it should be wired inline on the big battery cable. This needs to have no other wires between the battery + post and the disconnect in. All factory + wires should be after the disconnect out. Only exception to above is some will run a seperate wire before the disconnect (direct to + post) for the radio clock. Thanks for the reply- Unfortunately, when I ran it with the Alt wire to the to the starter solenoid the kill switch failed to work and would not cut off the running car as it should. The only way I was able to make it work was to connect the Alt. wire to the switched side of the kill switch but then the hot start problem reappeared (either that or a new problem). Not sure how the internals of the kill switch work but the battery should never be removed from the alternator when the engine is running. Modern cars use high power zener diodes as rectifiers in the alternator to snub the inductive kick if the battery is removed from the alternator when running. Almost any electronics in the vehicle could be damaged by the inductive kick. Automotive test specification ISO 7637-2 pulse 5 is a killer pulse. This pulse is 100V for about 1/2 a second and simulates disconnecting the battery from the alternator. If you're looking to protect the car from being stolen, you might want to try putting a switch in series with the spark unit, ECU, or the fuel pump. On my 930, I have a tiny toggle switch in series with the fuel pump relay. You can push the car or crank it all day and it won't start. It's a track side kill switch so corner workers can save my life in the event I'm unconscious (a standard op for cars used at the track-mine happens to also be streeted). I have no ECU, but I like the idea of taking power from my dizzy to effectively kill the cars ability to continue to run in the event I can not turn off the key switch. That said, even if my alt was removed from the kill switch functionality, since it would then be relayed from the solenoid on the starter (in Marks diagram) would it not have the same effect as removing power from the alt while the car is running when the car is turned off with the key? Or does the relay prevent a spike from going back to the system? |
Lo-Fi Version | Time is now: 17th May 2024 - 05:55 PM |
