Ford Solenoid Hot Start installation instructions, Mark Henry's method |
Mark Henry |
Apr 24 2017, 05:12 AM
Because this comes up so often I decided to make a tutorial on how I install the Ford solenoid.
The Ford solenoid fixes the common hot start problem of Bosch starter solenoid and it also reduces the load on the ignition switch. Although these instructions are for the 914 all aircooled VW's and Porsche often suffer from this problem and with minor changes this can be done to any car. The issue occurs because the Bosch starter solenoid needs a full 9 volts to kick in. The combination of age, heat, corrosion, many connectors, a small ignition switch and wiring running to the dash and back can degrade the volts to less than the 9V required. The Ford solenoid only needs about 3 volts for the 12V version and even less for the 6V which for our purpose works no problem. My installation drills no holes in the car, not a single factory wire is cut, no in-line fuses, fully reversible and simple with no added bullshit. Please this is not a discussion on if you prefer the wimpy (IMO) Bosch horn relay, want to cut and hack in a new wire or believe throat singing Vajrayana chants is a better method, start you're own thread. Of course as with any electrical trouble shooting the first order of business is always clean all of your grounds and make sure the chassis to transmission ground strap is in place and in good condition. I'll start right away with the money shot of the completed installation to show how clean this can be done. Attached image(s) |
ClayPerrine |
Jan 29 2021, 10:52 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I just use a IMI gear drive starter. No hot start problem since I put it on.
IMI High Torque Gear Drive Starter No, it is not cheap. But I have been running the same IMI starter, without replacement , on my red 914 for years now. I originally put it on the 2.0L 4 cylinder to cure the hot start issue. I moved it to the 2.4L 911ST engine when I did the six conversion, and that same starter still spins the 4.0L monster motor with no issues. I figure that starter will outlast the car. :cranky: |
Mark Henry |
Mar 29 2021, 02:40 PM
Another option is Bosch WR1 starter Kit. $27-$36 depending on where you shop Right in my 1st post my opinion is this fix is CRAP. (IMG:style_emoticons/default/dry.gif) Also said it's not a debate if you don't like it then move along. It's not a "starter kit" it's a VW Ghia horn relay. Look at that jangle of wires you have to hack in! You have to install it in the engine bay ..are you going to use a self tapping screw. I just ripped one out today and I'll be doing my fix thank you. (IMG:style_emoticons/default/smile.gif) I just use a IMI gear drive starter. No hot start problem since I put it on. IMI High Torque Gear Drive Starter No, it is not cheap. But I have been running the same IMI starter, without replacement , on my red 914 for years now. I originally put it on the 2.0L 4 cylinder to cure the hot start issue. I moved it to the 2.4L 911ST engine when I did the six conversion, and that same starter still spins the 4.0L monster motor with no issues. I figure that starter will outlast the car. :cranky: I also have an Hi-Torque in my /6 (IMG:style_emoticons/default/shades.gif) Starts my /6 good!! I still have the Ford bit only because I didn't take it off when I put in the Hi-torque starter. I should try without, I bet the Hi-torque only needs 3-4 amps to kick in, much like what the Ford solenoid needs. The problem is with the Bosch solenoid that needs a full 9 amps to kick in. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:25 PM |
