dansvan AK907 build thread |
dansvan |
Apr 26 2017, 11:49 AM
Newbie Group: Members Posts: 34 Joined: 15-June 16 From: Eagle River Alaska Member No.: 20,111 Region Association: None |
dansvan |
I think I got all pics small enough and going the right way now. |
dansvan |
May 4 2017, 01:11 AM
My car didn't come with fog lights. I bought some fog light grills from a member on here. Didn't want to use up an original set of lamps on this car so figured I'd mount some I had laying around.
I used these as the mounts. |
dansvan |
May 4 2017, 01:15 AM
I used these amber lights. Cost about 14$ each.
dansvan |
May 4 2017, 01:17 AM
dansvan |
May 4 2017, 01:19 AM
Here's the mount riveted in.
dansvan |
May 4 2017, 01:21 AM
I used rivnuts to replace the old screwclips.
dansvan |
May 4 2017, 01:24 AM
dansvan |
May 4 2017, 01:27 AM
Repeat on the other side. With these low cost lights, you can run amber, clear, fog, or even 100watt driving bulbs. (With proper wiring upgrades of course) these ambers are 35watt.
On to the next project. |
dansvan |
May 7 2017, 05:23 PM
Did some work mounting the radiator today. It's an almininum three row for a Honda Civic. Should work just fine.
Cleaned up area around where it will go. Removed the relay board mounts and installed the rear trunk hinge pivot kit from JWest as I didn't know how much room I'd have to do it later. That went smooth. |
dansvan |
May 7 2017, 05:24 PM
Fabbed up a lower mount for the radiator.
dansvan |
May 7 2017, 05:26 PM
Radiator trial fit.
dansvan |
May 7 2017, 05:27 PM
Top. Still have top mount and ducting to do.
Mark Henry |
May 7 2017, 06:38 PM
Wasn't there another member who moved to Alaska and took his 914 with him? (IMG:style_emoticons/default/idea.gif)
Lo-Fi Version | Time is now: 3rd May 2024 - 03:52 PM |
