1.7 too a 2.0 F.I. budget build up. what to swap ?, building 1 motor out of 2 |
insipidCarrot |
May 8 2005, 08:35 PM
Newbie Group: Members Posts: 11 Joined: 1-March 05 From: Long Island , NY Member No.: 3,693 |
I am looking to build up my 1.7 on a budget, mainly I want to punch it out to 2.0 with a higher compression and possibly a cam. What do I have too swap from the the 75 2.0 to the 1.7 ? Any suggestions for a set of pistons, stock bore or close with a higher compression and what about a cam that will work with the F.I. for the street. I am assuming the 2.0 head will have to be used and obviously the jugs, but are there any other pieces I am forgeting ?
Type 4 |
May 8 2005, 09:09 PM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
Rods and Crank.
Type 4 Unleashed |
May 8 2005, 09:20 PM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
Just, rebuild the 2.0, it will cost you more to turn the 1.7 into a 2.0, first off, you'd have to have the 1.7 (90mm barrels) case opened up for the 2.0 barrels (94mm), you'll save that money, using the 2.0 case. The 2.0 may or may not have a windage tray, but it will have the shelf to install a windage tray, where the 1.7 does not.
Just a couple of things to think about. |
Bleyseng |
May 9 2005, 07:02 AM
Nah, the 1.7 and 2.0 cases are the same and you don't have to open up the case cylinder bores.
tat2dphreak |
May 9 2005, 07:33 AM
...and pistons, and you should use the 2.0 heads too... just rebuild the 2.0... change the rings and cam(if you are going with carbs, or just want a hotter cam)... or you can put in 96mm pistons and have an instant 2056... the 96mm pistons are a better value than euro-spec flat top 94mm pistons... but for a budget build, just change the rings in the 2.0, and have the heads freshened... where did everyone get that you have to cut a 1.7 case? you have to open 1.7 heads for bigger pistons, but you don't have to cut any TIV cases until you try and run ~103mm pistons... the cases were ALL the same... |
Lo-Fi Version | Time is now: 2nd May 2024 - 02:23 AM |
