Turn Signal Light on Gauge Doesn't Work, Turn Signal Light on Gauge Doesn't Work |
gspreeman |
Apr 25 2017, 08:34 PM
Newbie Group: Members Posts: 22 Joined: 16-November 10 From: South Orange, NJ Member No.: 12,395 Region Association: None |
Okay, the turn signals on the outside of the car flash just fine, both left and right. My problem is the light in the gauge doesn't flash or even light up. I tested the wire that goes to the bulb with the turn signal on, both left and right, and there is no juice to the wire. Where do I look to fix the issue?
Spoke |
Apr 26 2017, 04:50 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Below is how the turnsignals in your car are connected.
Notice the L/R turnsignal indicator in the bottom left. It is connected to the flasher "C" contact with a Blue/White wire. If this wire is connected to the flasher it might be the flasher is not functioning correctly. BTW, you did test the bulb and it lights up, correct? Attached image(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 11:24 PM |
