Carbs vs FI |
Carbs vs FI |
Type 4 |
May 8 2005, 10:48 PM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
Here is the dyno sheet for the 2054cc engine with carbs.
Attached thumbnail(s) |
Type 4 |
May 8 2005, 10:49 PM
2054 with FI
Type 4 |
May 8 2005, 10:51 PM
The only change was the Carb was replace with the programable FI System.
MattR |
May 8 2005, 10:55 PM
This is a type 4 engine? A 2056?
Type 4 |
May 8 2005, 10:56 PM
No Type 1, just showing how with FI you get more power with the same engine.
bd1308 |
May 8 2005, 10:58 PM
a T-1 making 230HP???? am i missing something?
Type 4 |
May 8 2005, 11:01 PM
No Type1's make alot more power than type4 due to exhaust ports.
This is a daily driver 66 bug. |
bd1308 |
May 8 2005, 11:05 PM
HOLY COW....don't they max out to 2056 or something.....it's on somebody's site....
MattR |
May 8 2005, 11:06 PM
If T1s make more power, why do so many people go with a T4 conversion? Am I missing something?
Aaron Cox |
turbo?
MattR |
May 8 2005, 11:09 PM
It doesnt look like a turbo powerband to me. Turbos tend to be less linear. But what do I know, im just a kid. |
scotty914 |
May 8 2005, 11:12 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
i would bet that is a 10 k mile engine, i wonder what kind of case strengthing is done on a mag case to hadle that much power.
that motor must be at least 11 : 1 compression |
Aaron Cox |
May 8 2005, 11:18 PM
only street car i know of that is NA & ,akes more than 100 hp a liter is the s2000 (lots of modern tech in it)
MattR |
Yeah, I agree with scott. Its probably a drag motor or something running on race gas. Who else would dyno a bug motor? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/hide.gif)
edit: whoops, didnt see it was a daily driver. power to the nazi road oilers! |
Mueller |
May 8 2005, 11:34 PM
I'm willing to bet the difference wouldn't be as substantial on a stock or near stock motor......still a nice improvement.....figure $50 per horsepower if the FI cost $1500.....
no one is saying FI cannot give more HP, but you cannot claim 20-30% across the board on all applications..... Jakes new heads I believe are going to be using the Type I exhaust style, those should be some awesome parts to get a hold of once available.... |
J P Stein |
May 9 2005, 05:43 AM
Golly, Honda, Ferrari, NASCAR, et al, have to spin their N/A motors to 9k to get more than 100 hp per liter.....what a bunch of clowns. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
v82go |
May 9 2005, 07:10 AM
Resident Contrarian Group: Members Posts: 249 Joined: 9-December 04 From: Lakeland, Fl. Member No.: 3,250 |
Mini Cooper S > 1598 cc = 168 hp @ 6000 rpm |
Mueller |
May 9 2005, 08:05 AM
comes from the factory supercharged.......might be a good sized blower unit for a 914 engine (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
Tom Perso |
May 9 2005, 08:29 AM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
Don't forget about the Toyota 4A-GZE motor. 1600cc motor that spins to the moon. That has a blower, and has a clutch on it so you can turn it on and off. Sounds like a good use for that FIdle circuit on Megasquirt. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Later, Tom |
MarkG |
May 9 2005, 10:31 AM
Member Group: Members Posts: 314 Joined: 24-May 04 From: Colorado Springs Member No.: 2,102 |
I replaced this winter the FI system (stock D-jet)-injectors, TPS, CHT, MPS, throttle body, boots, vacuum hoses, trigger points, distributor breaker plate etc..
This Spring I have been replacing/updating the brakes and suspension on my '76 over the last 2 months; been sitting outside (but covered) all that time (including 2 blizzards). Saturday, for the first time in months, I decided to see if it would start so I could test drive it and seat the brake pads. Turned the key, and it started instantly - no hesitation, no cranking, after 2 months of sitting it started like it had just been turned off....... No carbs for me, thanks! |
Lo-Fi Version | Time is now: 29th April 2024 - 07:51 AM |
